Results 1 to 10 of 13
Thread: Rear Dash Cam Installation
    Nov 2017
    Western Australia
    Hi Peeps, just spent breakfast installing my new DOD rear dashcam. Thought I'd share a slight issue and how I solved it. Hoping this might help those of you who are undertaking installation yourself.
    The road bump was getting this cable for the rear dash cam through the rubber grommet wire loom thingee-ma-bob.
    Rear Dash Cam Installation-20171122_064226-jpg
    Normally I would use my kiwi engineered zip ties for holding my bumper together but today was different. The rubber loom's white clips as seen in the pic clip out from one side.
    Rear Dash Cam Installation-20171122_064600-jpg Rear Dash Cam Installation-20171122_064654-jpg Rear Dash Cam Installation-20171122_064739-jpg Rear Dash Cam Installation-20171122_064846-jpg
    Bob's your uncle:
    Rear Dash Cam Installation-20171122_065108-jpg Rear Dash Cam Installation-20171122_065302-jpg Rear Dash Cam Installation-20171122_065308-jpg Rear Dash Cam Installation-20171122_065404-jpg
    So this took a good 30 mins including coffee and toast breaks to feed the wire from the front to the back following the drivers side roof lining, end result looks neat and tidy.
    Rear Dash Cam Installation-20171122_065540-jpg Rear Dash Cam Installation-20171122_065550-jpg Rear Dash Cam Installation-20171122_065612-jpg
    Hope this helps someone!
    Jun 2017
    North Sydney, NSW
    Awesome. Thanks for that. Very handy.
    Churr bro!
    Nov 2017
    Western Australia
    @spacemannz haha... Churr my bro!!!
    Nov 2017
    Melbourne, Victoria, Australia
    Did the same myself over the weekend, nice and clean.
    I noticed when I removed the central plastic trim piece that it was not properly installed and the two side clips had been bent back. Luckily they hadn't snapped off, so I was able to reinstall it properly. Something to keep in mind for those of you planning to do this.
    Sent from my Nexus 6P using Tapatalk
    Jan 2017
    Melbourne, Vic
    How did you remove the central plastic trim?
    Nov 2017
    Quote Originally Posted by DigitalCourt View Post
    Just pull it from the glass side. There's a small clip on each end which will pop off easily and 3 stronger clips in the middle.
    You can bend it back and "feel" where the resistance is and you can see the holes for the 3 clips in mengy's photos. The central clips are metal so they won't break.
    Aug 2017
    Awesome work mengy.. got mine just installed as well and your guide helped.
    Did you hardwire your cam? Just wondering if you did which fuse did you tap into..
    Sent from my ONEPLUS A3003 using Tapatalk
    Apr 2019
    Sorry to revive an old thread here, but I've just gone and done this exact same thing .. except that I managed to partly break the bottom right clip (surrounding the lower rubber grommet boot). It still loosely snaps into place but not as tight as I'd like. Worried about possible water ingress into the roof. Has anyone ever replaced or found a fix for these? I'll probably just add some black sealant to the grommet boot to make sure, but keen to hear if anyone else has had similar issues.
    Pacific Paradise QLD
    Quote Originally Posted by DBO View Post
    Well I did it slightly differently After seeing another method of doing it I did this
    I ran a twin flex from fuse box behind glove box down trim and along floor under the door trims to rear quarter and up into left rear pillar behind taillights.after removing little pads that cover where you get to rear tail lights Earthed the neg there
    The did the following
    Remove top tailgate trim
    Using a trim tool wedge top of rear pillar trim out a bit and slide a mouse down to exposed hole Attach power cable and pull it up
    Put fingers or trim tool inside roof lining where there are 4 clips across the back
    Pop them off becareful to only work on the clips or you can pull them off the roof liner
    Put fingers inside tailgate and push the clip holding the flexi pipe towards centre of car and using a screwdriver on the outside lever it down gently and it will drop out Push a mouse down from the taildoor end and pull it out above roof lining.
    No need to touch bottom end of it at all
    Attach power cable and feed it into flexi pipe and work it through. Get it to camera.
    pull excess down into rear pillar You can do two things now. Either attach plug end of power cable to a ciggy holder and then to the wires from the front or I simply cut the plug off and used crimped joiners. My camera is a 12v one
    Tidy up wiring under roof lining and carefully reattach clips. refit taildoor trim
    All done well away from curtain airbags which blow down from the roof
    Jul 2021
    Hey guys, great tips in this thread.
    I am having some issues in getting past the b pillar. I am pushing up in the headlining and trying to run the wire, but there is just zero room. refer to step 8 in this link . Although that is a golf tutorial, I am assuming running that wire is the same.
    I would be hugely grateful to anyone that could share the way they ran the wire for the read cam past the b pillar
    Many thanks!
