The issue with snow chain clearance is not only with 2017- Tiguan.
It also applies to
Skoda Kodiaq
Volvo XC 90, current model
Audi Q7, current model
Audi Q5, new model
Nice summary. Just found this, seems winter tyres can let you off the hook for chains. Costly route to take but for those that are regular would be the go.
Australian regulations | Snow Tyres
It also applies to
Skoda Kodiaq
Audi Q5, new model
If you really want to go to buller, why not just buy a second hand pair of wheels and snow tyres? Lets be realistic, the 5x112 stud pattern is readily available (audi/skoda/merc/vw). Find a second hand set of wheels which Ive seen go for as little as $150 for a set, and then find some second hand tyres to allow you to fit the snow chains. Heck, you can even find a set with a lower offset so that you have more clearance.
It's really not that hard? Or as mentioned use spacers and just be done with it.
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
I can guarantee the tyres fitted to the R-Line will not like the cold and snow one little bit.
Europeans fit a set of winter rims/tyres.
Do what people do in NSW... park below snowline and catch bus or whatever to the slopes.
Or take the risk... and make sure you make a beeline to your car at the first sign of a blizzard.
There are issues when diamond pattern snow chain systems are used on high performance 2WD or AWD ‘summer’ tyres. On summer tyres snow chains will grip to the snow/ice but the tyre can slip or spin the chain even when they are correctly tensioned on to the tyre. The problem is worse when the vehicle has been parked at the resort because the low ambient temperature makes the tyres harder and therefore has even less grip to the chain.
Yeah, buying another set of wheels/tyres is an option for some. If you live in an inner city apartment though, like I do, there's nowhere to store a bike yet alone 4 wheels/tyres for the rest of the year.
And Buller isn't the problem because you can fit 0mm clearance chains.
It's Hotham that has the more stringent standards (diamond-pattern). And you still have to carry chains even with winter tyres fitted.
Non-factory fitted spacers are aren't really a viable option. They're illegal and invalidate your warranty and car insurance.
Last edited by latearrival; 10-08-2017 at 02:03 PM. Reason: Ignore this post. I was wrong.
Track down a member named 'adioz'. He's dealt with all of this.
Right, thanks, sorry. God knows what I was looking at
The info for Hotham seems a bit ambiguous tho'. Under Permitted Chain Types it says:
Diamond pattern chains - Mandatory.
Winter/snow tyres - Accepted
Does this mean winter tyres are accepted in-lieu of chains? Or does it mean that you can drive with winter tyres but you still need the mandatory diamond pattern chains?
