50c on it was a Sandisk LOL
Bought from a major retailer. The size was only off by a few 100MB in a 32GB but enough the SatNav update would not fit.
Looks like big is available in Taiwan and Japan now
Volkswagen Map Updates
2018 Allspace 162TSI R Line
Need some guidance here. Have downloaded the P90 discover pro file from the VW site as provided in this thread. Have unzipped directly to USB (fat32 format). Stick USB to my VW Passat and while the system recognises the USB.. I have done countless update searches (either through Nav Settings or General Settings) and return same error message "Error: no data available. Please insert a source with software update or check the source". I have already tried using SD card with exFAT format. Am at a lost what I am doing incorrectly. Please help!
Yup, two folders (Mib 1 & 2) and txt file. I have unzipped the whole file to the USB. It is the Discover Pro with 2 buttons. 2017 Passat 206 TSI R Line. From the maps website, it appears to be the discover pro 2016 Passat variant. So I downloaded that version (P90). Zip file of 25GB, unzipped is 31.38GB.
If you unzip them direct to whatever you are going to put in the car they should and do end up as the two folders and the text file in the root of the card or USB even if it has something else on it as have done it that way with a SD card with other stuff on it
Other and more common way is to unzip it to a folder on an HDD and copy the contents to the SD card
Either way worked for me
