Page 6 of 6 FirstFirst ... 456
Results 51 to 54 of 54
Thread: New map update for VW & Skoda available here
  1. #51
    Jan 2021
    Perth, WA
    You arent doing it on a MAC (heaven forbid) are you because that is too big Unzipped its 29.2GB or 31,371,034,6240 BYTES
    Should be 658Mb free space on a 32GB drive
    Am using Windows PC. USB is 256GB.. so plenty of storage.
  2. #52
    Jan 2021
    Perth, WA
    Quote Originally Posted by Anto View Post
    I had the same problem. The issue was that the two folders (Mib 1 & 2) and txt file need to be in the root directory of the usb and not the P90_N60S5MIBH3_ROW_NT folder that they’re packaged in from the download. Update took about 40 mins.
    Thanks. I shall try this later today and report back!
  3. #53
    Pacific Paradise QLD
    Quote Originally Posted by rookie123 View Post
    Has it got other stuff on it and if so unzip to an HDD and copy the contents of that folder to the root of your USB as said in above post. Sounds like it has unzipped to a folder on the drive if its populated
  4. #54
    Jan 2021
    Perth, WA
    Thanks, Anto. It worked as you described.
