Yes this can be disabled via VCDS and I have done this today :)
I've found this is adjustable in the Car menu settings under Driver Assistance. You can set it to either remember the last distance or default distance you want each time you start.
Printable View
Yes I have VCDS and have turned off stop/start, nag screen and enabled needle sweep on start-up. I hadn't found the setting for ACC default distance, however others have said you can set this up through the car settings screen so I'll give that a go in the morning.
In terms of sports and eco modes I thought that was under your driver profile... or am I not understanding what you're trying to save.
The car will remember sports and eco mode for acc but it won’t remember eco and sports for your gearbox unfortunately. So if you want to be environmentally friendly and you have to select eco everyone drive. It’s not so bad with sports as that’s just pulling the gear lever back.
I've fixed all your issues Tigger73 with OBD11, I've also set the Haldex to quiet as well but haven't had the chance to properly test it.
Only thing that is annoying is the slight clunk from the front RHS and now my LHS door has developed a rattle. Might as well replace the speakers once the trim comes off lol.
Yes all problems fixed with Vagcom except I haven’t changed any settings on the Haldex yet.
I really wanted to live with the stock car for a bit before going and making any changes. Now it’s a new and improved Tig [emoji16]
haha I know that feeling
If anyone is interested, disabling "Starting Vibration Reduction" allows more wheelslip when using launch control :)
any new Wolfsburg owners wanting to share their experiences so far? :)
One other thing I’ve noticed is that the steering wheel appears to be slightly offset (right) in relation to the driving position.
http://www.vwwatercooled.com.au/foru...c3f2d5f9-1.jpg
Whether this is intentional or a requirement for airbags / passenger protection / crash rating.
