Page 97 of 118 FirstFirst ... 47879596979899107 ... LastLast
Results 961 to 970 of 1174
Thread: Mk2 Tiguan VCDS Tweaks
  1. #961
    Pacific Paradise QLD
    Quote Originally Posted by Wazza 162 View Post
    Learning a bit more with each step but still not showing in the light settings.
    Byte 5 isn't shown but I presume it's the light assist box, there are 2 more unlisted boxes under that one do I leave them alone?
    Close to giving up but I must be close to activating HBA.
    THANKS for your patience.
    Get your definitons correct or you will end up well in the s**t if you mix them up
    Its BYTE 21 BIT 5 and in mine it goes down to BIT 4 and then it says Light Assist (AFS) Dynamic light assist so tick the second box in that
  2. #962
    Feb 2018
    Blog Entries
    1
    Mine is the same except High beam assist instead of Dynamic light assist with three boxes, I tick the first box
    MY18 Tiguan R Line Black-162 Highline TSI
    Drivers Assistance Package - Sunroof - Tow Bar
    Ordered July 17 Arrived December 17 Delivery Jan 18
  3. #963
    Why that one Worked it out as when i click on it it gives the option of HBA
    I know If have DLA enabled and so it will bring that up when I tick the box I did
  4. #964
    Feb 2018
    Blog Entries
    1
    I'm so close, now have it in my settings and activates on auto lights, stalk pushed forward but comes up Fault light assist in dash centre
  5. #965
    Oct 2018
    Melbourne, VIC
    I got that same error when I first did it - turns out I'd been counting the bytes from 1, instead of from 0.
    i.e. byte 0 starting at the top, not byte 1.
    Any chance you made the same mistake I did?
  6. #966
    Feb 2018
    Blog Entries
    1
    Quote Originally Posted by PDMJO View Post
    Maybe only going on hillbillys instructions so I would have thought he would say the byte by number e.g. byte 0 or byte 1 etc
  7. #967
    Its as plain as the nose on your face as under the big digits which is the first BIT in the BYTE you are on is the BYTE number you are on.
    Top row 00
    under that it says BYTE 21 or whatever you have scrolled to
    Hexadecimal always starts at 00 AFAIK
    You are both getting definitions mixed up which can only lead to confusion
    The bottom number is a BYTE which has a certain number of BITS which are the numbers in the top row..
    Try to get it right or instructions will be incorrect
    While it doesnt quite follow the protocol of 8 bits to a byte it is basically the same thing
    Bits and Bytes
    Why didnt you just use the APP It works.
    If you havent got enough credits Open the program every 24 hours and you get a free credit and if you open 5 ads you end up with 6 credits a day. Ive got 630 ATM for virtually doing nothing.
  8. #968
    Feb 2018
    Blog Entries
    1
    Top row 00
    Bits and Bytes
    Yes l did mix myself up with the message from PDMJO, bit 1 means bit1 etc. Byte numbers bring up the difference pages of bits.
    I hope that is right.
    I have redone again and all appears to be working except the fault light assist in dash centre comes on when pushing stalk forward
    I did originally use the app but had to reverse it as I had no high beam even pulling back the stalk for highbeam flash didn't work.
    Where are the ads?
    Thanks
  9. #969
    Where are the ads?
    Thanks
    Come on dont you do any research yourself Open the Wallet in the program and play around till you find out how
  10. #970
    Jun 2019
    Hi all, i have an MY20 Tiguan Allspace Highline, S&V, R-Line.
    I purchased a Ross-Tech cable and have been making a few changes.
    So far i have managed to do the following;
    Adaptation changes;
    IDE06419-Driving profile switchover
    ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen
    IDE04159-Deactivation of start-stop function - didn't work
    IDE12467-Tubes illustration
    IDE05111-Fee-based traffic information (TMC) - yet to confirm if this worked
    IDE04158-Activation of start-stop function - this didn't work
    IDE06588-Ignition active message: actuator
    Long coding changes;
    Overtaking right prevention active
    Sat Nav initial disclaimer
    display volume to be replenished
    display acceleration
    The one thing that i desperately want to change, is the stop/start function.
    Does anyone with a new platform vehicle have a solution for this?
    I looked for the temperature method, but couldn't find anything.
    latest coding form the car below.
    Tried to put in coding but website tells me it is too long.
