Page 62 of 68 FirstFirst ... 12526061626364 ... LastLast
Results 611 to 620 of 678
Thread: Mk2 Tiguan Tuning
  1. #611
    Feb 2020
    Sunshine Coast, Qld
    It does seem high, although you seem to be able to get a lot from this engine with minor mods.
    I just calculated the kw and nm from the APR data calibrations, in my original post.
  2. #612
    Oct 2018
    Melbourne, VIC
    Quote Originally Posted by digger View Post
    Thanks INASNT for the reply.
    So, the stock Tiguan 162TSI actually pumps out 182kw and 375nm on 98 RON and 162kw and 350nm on 95 RON?
    Just interested as my 2019 Mazda CX9 gets an extra 16kw for using 98 RON. Goes from 170kw to 186kw, although there's supposedly no change in nm though.
    I’d be inclined to assume with 98 the max output is 162kw, rather than 162kw being the minimum. Just going based off drivetrain loss, 182kw seems too generous.
  3. #613
    Dec 2010
    Helensburgh
    I use both 95 & 98 and my bum dyno cannot tell the difference.
  4. #614
    Sep 2011
    Melbourne, Victoria
    Doesn't it say min 95 on the gas cap?
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  5. #615
    Quote Originally Posted by PDMJO View Post
    Actually I think that 180kw on 98 is probably about right. I'm comparing this to tuned Mk1 Tiguans and what they would output on the dyno compared to a gen2 162TSI in stock form. The stock 162 Tig is only a few kwaw down on a stage 1 Mk1 Tig.
    Also 0-100 times tend to confirm that to be the case also. So I really don't trust VW's brochure 162kW figure but I have confirmed the claimed stock 0-100 for the 162TSI is pretty spot on at 6.5sec. Which doesn't stack up given that the last of the gen1's with 155kW was 7.3sec. So how can you run almost a full second quicker 0-100 with only 7 more kW?
    All things point to 182kw as stock output for the 162TSI Tig. My 162TSI was running at 137kwaw on the dyno and if you factor in around 25% driveline losses for the AWD and DQ500 then the numbers all line up.
    Oct 2018
    Melbourne, VIC
    I gladly stand corrected!
  7. #617
    Quote Originally Posted by Darkshrimp View Post
    Is that actually right? Seems like a huge increase change for a fuel change?
    No that’s not correct. If you read the fine print you’ll see the 162kW is the VW “claimed” figure whereas the 182kw is the measured figure by APR on 98.
    I think if they measured on 95 it would probably run mid-high 170’s.
    Feb 2020
    Sunshine Coast, Qld
    Great, thanks for the insights tigger73.
    2019 VW Tiguan 162TSI R-Line + Sound & Vision Package - Tint - Roof Bars.
    2019 Mazda CX9 - Tint - Roof Racks.
  9. #619
    Dec 2010
    Helensburgh
    The answer might lay in how the ratios in the 7 speed are stacked against the final drive ratio, not saying that is the answer but it could be part of it. My 125TDI Superb definitely had way more than 125 killer wasps.
  10. #620
    Dec 2010
    Helensburgh
    Quote Originally Posted by INASNT View Post
    No, it is on the petrol flap, sorry I couldn't resist and will leave the building now.
