Page 22 of 33 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 322
Thread: Map update?
  1. #211
    Jun 2013
    Act
    There shouldnt be any need for that should there
    Mine suffers from needing that warning too.... a defect with these Tiguans?
    May 20 - Nov 19 MY20 Tiguan 162 TSI
    May 16 - Apr 16 Mazda 3 Sp25 GT - 2020 hail storm write-off
    May 13 - 2013 Mk7 Golf Highline.
    May 10 - 2009 Falcon G6E with beige leather.
  2. #212
    Pacific Paradise QLD
    Red face
    Quote Originally Posted by Nauend View Post
    No its a defect with the nut holding the wheel LOL
  3. #213
    Feb 2018
    I don't see any diffence after map update.
    I was going to Rockdale VW and it is 589 Princes Hwy Rockdale.
    Navigation took me to 589 Princes Hwy Kirawee. After map update, I tried again still same.
    And why there is no international airport in system?
  4. #214
    Quote Originally Posted by akajjo View Post
    Hardly the maps fault you didnt tell it the correct information is it. Often roads go through several suburbs and if you dont tell it the correct one you will end up in wrong place as I have found out .
    Eg was going to a van park in Coburg and didnt put that in and ended up in Elizabeth St MELBOURNE at 3 pm on a Friday with a 25ft van on . Was great fun NOT.
    Airports etc are POI so not really the maps fault either and surely you would know where the airport is, International or not
  5. #215
    Jul 2020
    Whadjuk, Kwoppa Keppa / Fremantle Western Australia
    Well buggered if I know,
    I downloaded (4.5 gb )and unzipped it to a SD card using winzip but the total file s size is only a bit over 5 GB, which is a long way from 31 gb
    any ideas what I am doing wrong?
    2018 Tiguan Allspace TDI DAP+S&V
    2010 Mazda RX8 GT
  6. #216
    Quote Originally Posted by sinkas View Post
    Which Nav unit have you got The Discovery Pro with NO buttons or the lesser one. NONE are 31gb either The Pro one is a bit over 28gb
    Sounds like you downloaded the wrong one
    Unzipped map 88 is 28,7 GB, 30,870,208,512 bytes
  7. #217
    Feb 2018
    I typed full address "589 Princes Hwy Rockdale" and it turned to 589 Princes Hwy Kirawee and and otherday
    I was going to Fivedock VW I type all the way to the end "155 Parramatta Road Fivedock"
    but when I pressed OK it turned to 155 Parramatta Road Auburn.
    It seems have problem with same st name and number and different suburb.
  8. #218
    Feb 2018
  9. #219
    well as you have to put the "town" or suburb in first it will make a difference as to what you put in.
    So shouldnt you put Fivedock in first then the street,especially if its a long road going through several suburbs
    Eg where I live one part is considered to be Maroochydore but is actually Buderim and if you dont put the correct one in you dont get the right street to even come up
    Work down from the top
    Attached Thumbnails Attached Thumbnails Map update?-20200914_110309[1]-jpg
  10. #220
    Jul 2020
    hi its the media with buttons, ill try again
    2010 Mazda RX8 GT
