Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: List of OBDEleven mods and how to do the 30 of them
    Pacific Paradise QLD
    List of OBDEleven mods and how to do the 31 of them
    Here is a list of the 31 I have done to my car . I accumulated credits by logging in each day for several weeks and got 6 a day so i could use the apps when needed . Now still have nearly 700.
    Due to VW locking access to modules in 2020 models these probably/possibly wont work on them
    https://drive.google.com/file/d/1XT_...TPRJFZyeG/view
    Have corrected the DLA instructions as I left some of it out
    UPDATED 27/02/21
    Fixed access 3/4/2021
    Apr 2018
    Thanks for putting this together
    >> 5 Disable Sat Nav Safety Warning
    Would definitely like to go get rid of this annoying nag screen
    >> 14 Adjust speed in Dash to be correct at 100k kph with 20” wheels
    Does this mean our speedo is wrong without this mod ?
    >> 15 Ripping CD _Media _ data
    What does this mod do ?
    Quote Originally Posted by FastMitch View Post
    Does this mean our OD is wrong without this mod ?
    5 is easy to do
    14 no odo is different to speedo Am yet to run my two cars over a test course to see if it get any difference
    15 allows you to rip a CD into the Media AFAIK have it but havent tried it Will do tomorrow
    Ok heres how to do No 5 Go to Menu/Media/ Settings/ Manage Jukebox.
    Put CD in and it will read it/select source(CD)obviously/go to bottom of screen select import and wait as it does it Takes about 7 minutes.
    It wouldnt do an Audio DVD with 5.1 sound on it
    Apr 2018
    5 is easy to do
    I assume you mean easy with OBD11 as opposed to just doing it via the main Discover Pro Screen ?
    Side note, how much did the OBD11 cost to buy ?
    Yes it isnt in the screen at all as it activates it in the internal coding
    I paid $130 second hand a year ago for a V1 Here is the new one and you DO need the Pro one to do coding
    OBDeleven V2 Pro Pack – Audi, Skoda & Volkswagen Diagnostics – AutoInstruct
    You also need a Android smartphone to run it newer than Android 5.0
    There are cheaper other makes but only that one will do what we want
    Look on Farcebook market place There are NONE on GUMTREE
    Apr 2018
    Thanks mate. OBD11 was more than I thought these things cost.
    OBDeleven Diagnostic System – Shop – AutoInstruct
    • $209.13 OBDeleven V2 Starter Pack - (Not Pro, 100 Credits)
    • $256.38 OBDeleven V2 Pro Pack - (Pro Licence, 200 Credits)
    • $329.13 OBDeleven V2 Ultimate Pack - (Pro Licence, 500 Credits)
    Couldn't find pricing if you need to purchase additional credits. It only comes with '100 Credits'. Do you use these pretty quick ?
    As I will probably only use the device once not to make some minor mods (disable nag screen etc), not sure if its worth it for me.
    Not sure what this is: OBD-II Engine Code Reader with Bluetooth(R) Technology | Jaycar Electronics
    Oct 2018
    Melbourne, VIC
    As the story typically goes, it's hard to stop at just one - they make it too easy to modify further and to stop after only one.
    Credits can be obtained for free by watching ads every day. If you get the pro version, you don't need credits, as you can do the long-coding rather than the apps, which automate the coding process and consume credits to do so.
    Most apps only use 10 credits and they are about $30 for 75 I think.
    I spent several weeks logging on every day and let the ads run (30sec each) and you get a credit for loggin in and 5 for the 5 ads I have about 680 atm and i rarely use them
    The thing from Jaycar is a fault reader nothing else
    Down load the OBDELEVEN app from the Google playstore and have a look through it
    Ask on here for some one in your area to do it for you for a slab or something. Each one only takes 5mins at the most
    Apr 2018
    Thanks, will check out the apps and see if its better to hit up member with a slab or something.
    Works out cheaper buying from obdeleven.com - $194 for the OBDeleven V2 Pro Pack - (Pro Licence, 200 Credits)
    At ~$100 I probably should have bought the OBD11 v1 when I bought the Tig
    Went through some apps briefly, there were a few.
    >> Auto Folding Mirrors (App)
    Is this auto / manual App option not available as default on the Discover Pro Main Screen ?
