Originally Posted by
dgp
Yes, thank you I did. When opening the links, they just hang, nothing happens.
I didnt see any any mention of issues arising, or not arising from using the Skoda maps in VW’s, hence my question. ope126 looks to have installed the Skoda software into his Passat, but I would be interested to know if anyone who frequents this forum, or has knowledge from other sources, if using this software could cause issues.
I have an MY20 Tiguan Allspace, that does not behave exactly like the 2019 model (I can’t disable stop/Start for instance), and don’t want to brick the thing.
I now have another question, did VW supply you with an SD card, or did you just use your own.
You are doing something wrong or using a MAC then because I have downloaded the one from Chalnoths link this afternoon and again right now and it works
I said it works as did the previous one I got from the Skoda site in June I also said above, that when the two differently named files are unzipped they are IDENTICAL
What MMI I do you have as a Discover Pro which this map is for doesnt use a VW SD card Only discover media or similar do so.
So no if you do everything correctly you wont brick anything It will simply say "invalid map information " . As far as Stop start is concerned there are several ways to disable it .
What are you using to try to do that
