do you have a link to the video?
The button has been reluctant to work on the first push as it used to and the other day I thought it was not going to work at all so some investigation was called for. I did a search and a Skoda owner had kindly been there before me and posted a video on how it needs to be pulled apart and the contacts cleaned. This is just a heads up if you have the same problem and mine is working fine now after an overhaul today.
2018 Allspace 162TSI R Line
Good to hear you were able to revive the switch by cleaning the terminals - I hope it works long term. My start/stop switch was playing up also (2015 Golf GTI - was having to push the button 2-3 times to turn on/off the engine) and I bought a new one (VW Central sells them, they are $140). Works perfectly now.
5G2959839A3Q7 - Genuine VW Engine Ignition Start Stop Button Switch Aluminium (RHD) Fits MK7 & MK7.5 Golf GTI & R
2017 Ford Fiesta ST
I've run into this problem also with the car 1 year out of warranty VW customer care said that they may only provide part goodwill.
So I think I'll try cleaning the switch first with alcohol/cotton bud and see if that fixes it. Disassembly/cleaning to happen on the weekend...
We had ours replaced by the dealer about 6 months out of warranty, parts and labour
I think it depends on how hard the dealer pushes and your relationship with them
Whilst this option might not suit everyone, there's also the option of purchasing a genuine VW part for Chinese-market VWs via aliexpress.
I haven't tried these switches so I can't vouch for them, however I've purchased interior parts from this seller to replace scratched piano-black trim bits in my car and the parts that I received were all genuine, with correct markings and packing labelled "FAW Volkswagen". Caveat emptor and all that jazz
FAW-Volkswagen - Wikipedia
For VW Golf 7 GTI R START ENGINE STOP button switch 5GG 959 839|Car Switches & Relays| - AliExpress
I pulled my switch out today and cleaned the contacts. Works 100% now.
Here's a quick guide:
1) Remove the gear lever trim by using a trim tool. Start at the top as there's clips at the base.
2) Undo 2 x T20 Torx
3) Remove surrounding trim
4) Disconnect start/stop wiring. You'll need to insert a small screw driver to disengage the locking tab. Next pull out the silver spring clips. Careful as they'll spring out and go where you don't want them to.
5) There's 4 little clips that need to get disengaged to open up the button. One is hiding under the sticker:
6) Get a cotton tip and some isopropyl alcohol to clean the contacts. Reverse the process to put everything back together.
