Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Ignition Push to Start Button
    Dec 2010
    Helensburgh
    The button has been reluctant to work on the first push as it used to and the other day I thought it was not going to work at all so some investigation was called for. I did a search and a Skoda owner had kindly been there before me and posted a video on how it needs to be pulled apart and the contacts cleaned. This is just a heads up if you have the same problem and mine is working fine now after an overhaul today.
    Aug 2018
    do you have a link to the video?
    2018 Allspace 162TSI R Line
    Good to hear you were able to revive the switch by cleaning the terminals - I hope it works long term. My start/stop switch was playing up also (2015 Golf GTI - was having to push the button 2-3 times to turn on/off the engine) and I bought a new one (VW Central sells them, they are $140). Works perfectly now.
    5G2959839A3Q7 - Genuine VW Engine Ignition Start Stop Button Switch Aluminium (RHD) Fits MK7 & MK7.5 Golf GTI & R
    2017 Ford Fiesta ST
    I've run into this problem also with the car 1 year out of warranty VW customer care said that they may only provide part goodwill.
    So I think I'll try cleaning the switch first with alcohol/cotton bud and see if that fixes it. Disassembly/cleaning to happen on the weekend...
    Mar 2008
    Melbourne Australia
    We had ours replaced by the dealer about 6 months out of warranty, parts and labour
    I think it depends on how hard the dealer pushes and your relationship with them
    May 2007
    Aug 2021
    Whilst this option might not suit everyone, there's also the option of purchasing a genuine VW part for Chinese-market VWs via aliexpress.
    I haven't tried these switches so I can't vouch for them, however I've purchased interior parts from this seller to replace scratched piano-black trim bits in my car and the parts that I received were all genuine, with correct markings and packing labelled "FAW Volkswagen". Caveat emptor and all that jazz
    FAW-Volkswagen - Wikipedia
    For VW Golf 7 GTI R START ENGINE STOP button switch 5GG 959 839|Car Switches & Relays| - AliExpress
    Quote Originally Posted by petemac110 View Post
    I know a few people have bought the AliExpress buttons. The only issue is that they are for RHD Tiguan and when installed the STOP/START lettering is upside down
    It still works like it should just looks a bit odd.
    I pulled my switch out today and cleaned the contacts. Works 100% now.
    Here's a quick guide:
    1) Remove the gear lever trim by using a trim tool. Start at the top as there's clips at the base.
    Ignition Push to Start Button-289265227_10159176334117775_2415091840414077433_n-jpg
    2) Undo 2 x T20 Torx
    Ignition Push to Start Button-290309549_10159176335062775_1376064432796071031_n-jpg
    3) Remove surrounding trim
    Ignition Push to Start Button-289456204_10159176335307775_7957155058203596467_n-jpg
    4) Disconnect start/stop wiring. You'll need to insert a small screw driver to disengage the locking tab. Next pull out the silver spring clips. Careful as they'll spring out and go where you don't want them to.
    Ignition Push to Start Button-289657135_10159176335412775_7385691186775156052_n-jpg
    5) There's 4 little clips that need to get disengaged to open up the button. One is hiding under the sticker:
    Ignition Push to Start Button-289102833_10159176335657775_497147841784025686_n-jpg
    6) Get a cotton tip and some isopropyl alcohol to clean the contacts. Reverse the process to put everything back together.
    Ignition Push to Start Button-289163180_10159176335887775_9083604669458551438_n-jpg
    Aug 2021
    Oh, I wasn’t aware of that issue! Thanks for the heads-up!
    Nicely done regarding the switch cleaning too!
