Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Ignition Push to Start Button
  1. #21
    Mar 2019
    Quote Originally Posted by Surly78 View Post
    Thanks for this.
    Worked straight away after a quick clean although I also didn't notice and dirt/dust etc.
    Can also attest that you need to be careful with the silver clips holding the button in place.
    Lost one, but the one remaining still holds it in place.
    I tried this too - and works great. One tip though - the reverse order is NOT the same as disassembly - I put the switch in and tried to slide in the silver clips up from underneath (reverse of how I got them out).
    However, what you actually need to do is put the silver clips back on the sides while the button is out of the car, and then drop the button in from the front face, and it will lock in place.
    Also, I cleaned the blue contacts in the rubbery/silicone bit as well. seems to have worked well.
    Unfortunately, I seem to have broken some of the clips on the 'surround' part - so take care pulling that bit out.
  2. #22
    Mar 2019
    Quote Originally Posted by kabbage View Post
    This really works well - starts and stops first time every time now. Sooooo much better
    Although, it's only 4 years old, and you *shouldn't* have to do this (I guess I could have taken it back and had it fixed under warranty, but this seemed so much easier).
  3. #23
    Aug 2020
    St Kilda, VIC
    Thanks for posting guys, worked well form me. Thanks to @tigger73 for the great pics. A bit tricky pulling the switch apart but be patient. Used a couple of small screwdrivers to wedge between the tab and clip while working on the others. Also, put a hand towel around the gear shifter after removing the trims to prevent losing any bits in the abyss.
