View Poll Results: Do you prefer Traffic Sign Recognition or Navigation Speed Limit
Voters
92. You may not vote on this poll
  • Traffic Sign Recognition
    24 26.09%
  • Speed Limit on the Navigation System
    7 7.61%
  • A combination of the two, which VAG doesn't allow in Australia.
    61 66.30%
Page 17 of 30 FirstFirst ... 7151617181927 ... LastLast
Results 161 to 170 of 300
Thread: A guide to enable EU specific features for AU Spec Tiguans
  1. #161
    Oct 2016
    SYDNEY
    hi everyone,
    how can i backup my current car's setting before using OBD to enable new features. thank you
  2. #162
    Jun 2016
    Melbourne, Victoria
    OBDeleven takes a log of before / after values every time you make a change. To restore the changes you have to manually check the log and amend the adaptations accordingly.
  3. #163
    Oct 2016
    SYDNEY
    thanks Simon for instructions, and
    Adaptive Lane Guidance
    1. Select Coding, and change Point of Intervention to Early (Setting Via Menu)
    select Coding or Long coding ... in the OBDELEVEN i only am able to see long coding ....sorry for this ...please be patient ....hehe
  4. #164
    May 2017
    Quote Originally Posted by theitchy View Post
    yes, long coding (and yes, it confused me too).
  5. #165
    Oct 2016
    SYDNEY
    thankks sharp ..thats why my friend call me banana...hehe
  6. #166
    hi everyone,
    Like this:
    Repeat this process for each control module listed in the first screenshot for your car. My screenshot is from my test bench (my "virtual car"), so it only lists 5 x modules - but a real car will have many more modules.
    It does take time to establish a complete back-up database, but it's a worthwhile exercise IMO for when (not, "if") the brown stuff and the fan meet - especially if you intend to use OBD11 Apps (which don't/haven't-normally recorded the before/after change values)
    Another advantage of having a back-up database is that you can scrutinize the settings on your car before implementing a tweak - without the need to hook up the OBD11 dongle. Very useful if you want to see if the tweak is suitable!
  7. #167
    Oct 2016
    SYDNEY
    Thank you very much DV52 ... I appreaciate this kindness very much .....i struggle backing up these things and already made change for Traffic and LED light. However this would be a big help before i start stuffing up everything ...hehe.....thank you kindly DV52
  8. #168
    Apr 2017
    JHB, South Africa
    Has anyone managed to code rear DRL yet?
  9. #169
    Quote Originally Posted by cabby09 View Post
    caddy: it's done a number of ways - Scandinavian DRL tweak being one of these -Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht>active. But this change also lights-up other lamps like the dash
    Or, you could use the technique below - if you have OBD11 (you 1st need to select Central electrics module):
    and if you have VCDS - it's done like this (you 1st need to select the BCM and enter the magic number 31347):
    EDIT: OK - slight change to the screenshots above which work for MQB platform vehicles prior to MY17 build. If your car has the newer ODX modules (I suspect the new Tiggy has these), then the "Parent" part of the adaptation channel name is Außenlicht_Front (instead of Daytime running lights). If you are using VCDS on the new Tiggy, the full adaptation channel name is ENG10575-ENG115833-Außenlicht_Front-Fahrlicht bei Tag.
  10. #170
    Oct 2016
    Artarmon, NSW
    Excuse my ignorance. What are rear DRLs? Why would you want to switch them on? Would they be confused with normal rear red lights?
    Thanks.
    David
    Sent from my SM-G930F using Tapatalk
    Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait. I took delivery on 11 March 2017.
