Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Finally got bitten by the notorious DSG
  1. #21
    Nov 2018
    Gold Coast
    Quote Originally Posted by REXman View Post
    You are not unlucky. We all are. As I have mentioned before in an earlier post, we had the Polo (x1), Golf R (x1) and Tiguan (replaced twice!!). All brand new cars. All needed changing. The Tiguan I bought after the golf and did so with some confidence given it was supposedly tough DQ500. It got changed twice. To be fair though my current one is lovely and the Golf R I sold to my sister and both are now driving we’ll touch wood. Smooth and quiet.
    What a **** around though to get to that point.
    I could be lucky and find it’s only a seal, won’t know until Audi techs look at the car. Driving it, you wouldn’t know, and the leak is small. See how it pans out. Glad I waited until a full service and inspection of the underside of the car before I got a tune.
  2. #22
    Nov 2018
    Gold Coast
    Quote Originally Posted by franjae View Post
    When you refer to gearbox, you mean the bevel box? So you’re had three replaced.
    I’m still investigating the vibration issue in the drivetrain of my Tig. Yesterday they found a leaking bevel box, I think the rear one? Hopefully this is the cause of that vibration. Took another 162 out for a drive, nothing, no vibration, and neither did the 132. The 132 drove just as nice..... :-0
    Yes, bevel box leak. Which can either mean the tranny is stuffed or a seal issue. I’ve had TWO complete DSG gearbox replacements in my Tig which I no longer own. The first was detected at just over 1000klms and I had to wait 4 weeks for a new gearbox, the second was replaced at 8000klms and again had to wait for a new box. My new car, which has a DQ500 as well (RS3) has a leak at the bevel box, until Audi techs look at the car in a few weeks I won’t know if it’s a seal or another gearbox replacement. The car has 16k on the clock, is unmodified and has had two services done by Audi. (Interim at 7.5k and scheduled 15k). After I purchased it I sent it straight to my VW Audi service and Euro specialist and gave it a full birthday, that’s when the bevel box leak was detected. They serviced it and wrote a report and because it’s a warranty claim it’s now booked in with Audi.
  3. #23
    Apr 2015
    In my family we are on DSG equipped VW #6;
    MK6 Golf GTi
    MK7 Golf 118 Comfortline (twincharger)
    MK7.5 Golf 110 Highline
    Mk7 Golf Gti
    Mk5 Polo Gti (1.8 )
    MK7.5 Golf R
    Only one of them, the Polo Gti, has had a gearbox issue which required replacing the even gears mechatronic unit. All of the others have performed faultlessly with only regular servicing at the local VW dealer.
    Tip, when the even gears mechatronic unit failed it still shifted 1/3/5/7 OK, but the engine went into limp home mode (super rich, low rpm limit, jumpy throttle etc). Rather inconvenient in peak hour traffic. I turned off the ignition, removed the key and then replaced it and restarted, this reset the limp home mode and it drove quite well the rest of the way to work and home again that afternoon, still just using 1/3/5/7. I dropped it off at the dealer the next morning, they told me if they had had a mechatronic unit in stock I could have waited while they fixed it as it's an external, bolt on parts swap.
    Overall very little in the way of DSG issues and FWIW none of them has had a single other mechanical issue.
    Gary
  4. #24
    Apr 2015
    Quote Originally Posted by southtig View Post
    It is nice to see some positive stories but 1 from 6 is still a higher problem rate than most would expect or be happy with. I think I could buy 6 landcruisers or even 6 grand cherokees and expect to not have a single gearbox issue.
    I posted on the turbo thread when it probably should have been here, but I am considering buying a Tig and modding it while in warranty and these posts certainly have got me nervous about VW's response. Most posts suggest they do eventually fix issues if pressed but they don't exactly seem to be bending over backwards to admit there are known problems or to take ownership like Toyota, Subaru and even Jeep have done in the past with my cars. I have had warranty engine work (valve train) performed by Subaru without them even losing a step when they learned about the turbo kit and flex fuel tunes on the car.
    You must have been very lucky with your Jeep/s, one of our drivers tows his race car with his Jeeps and they are always being worked on for some reason or another. Trim loose rattling or falling of, bluetooth not working, noisy drive train requiring diff replacement, twice. Excessive tyre wear due to moving wheel alignment (I ended up fixing it with some aftermarket alignment parts) and the auto gearbox in his last 2 have been horrid when towing, hunts up and down between gears incessantly, been replaced once under warranty. Their terrible reputation is why Jeep has gone to 5 year warranty, to try and improve their quality image.
    In the VW's one only issue of any kind in 10+ years, travelling many than 600,000 kilometres with 6 cars is not something I consider to be remotely an issue. And 3 of them have been driven hard, with 2 having seen track time.
    Gary
  5. #25
    May 2010
    So wolfsburger 3/3 gearbox issues.
    Me 3/3 gearbox issues.
    sydneykid with the plethora of VWs, 1/6.
    7/12. Not the best.
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
  6. #26
    Nov 2016
    MAPLETON Qld
    7/12. Not the best.
    How about the rest of us with no gearbox issues?
  7. #27
    May 2010
    Quote Originally Posted by Hole46 View Post
    7/13?
    Actually my Tiguan has 2 done so 8/13
    You’re never going to get definitive stats from a forum thread, the manufacturer, or anywhere really. But it is definitely an undeniable concern when I have had 3 VWs with 4 DSG replacements, and another member has had 3 DQ500 failures from 3. I have spoken to my best mans sister who also got a lemon. Where my wife for example has bought 2 Mazda’s brand new (MPS3) and a CX9 and has had zero issues.
    I can’t speak for anyone else but all three VW vehicles I bought were brand new. Kind of disappointing. Only reason mine got resolved is because I stayed on it like a hawk, most of the time VW saying to me there was no issue. I was also lucky in that I found a quality service center who knew what they were doing. There’s a few other members who haven’t been so lucky.
