Results 1 to 10 of 16
Thread: Replacing Fog Lights - Pure White Light
    Jun 2018
    Hi Guys,
    I have a fully loaded Tiguan R Line.
    I'm a little bit disappointed that the front fog lights have a yellow tinge to them, in my opinion it makes the car look cheap.
    Looking at replacing them with a pure white light to match the main headlights.
    Has anyone else done this? I can't seem to find the globe specifications in the manual. Also, are there any error codes that get reported if I replace them?
    Quote Originally Posted by nbolz View Post
    Hi Guys,
    I am also considering doing this. Apparently the yellowish colour helps to cut through the fog a bit better but that is a rarity where I live. I believe the unit is called an H8 (with right angle connector). See the attached from Ali Express. I believe these are common to most recent VAG vehicles, but again concerned about the issue with errors. I understand from YouTube vids that it is a simple task to change albeit a bit of a squeeze to access from inside the fender lining. If you browse Ali Ex you will find other sellers providing some info and claiming to be "error free"
    I see there are also full LED interior light kits specifically for the new Tigs. I would be interested also to hear from wiser folks.
    Sent from my SM-G960F using Tapatalk
    Quote Originally Posted by timholder57 View Post
    More so others can see you better, notice on a foggy day you generally notice the cars with warmer tungsten headlights than once with HID/LED headlights? This is because during the day, fog actually appears quite white and projecting white lights through a white fog makes it harder for others to see/notice you.
    From a driver's perspective any light frequency will just behave the same in terms of "penetration" as he wavelength is much smaller than the fog particles themselves.
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
    Pacific Paradise QLD
    The optimum light output is reached about 4000-4500k if you go higher it appears brighter and bluer but in fact does NOT give more light
    Color Temperature (Kelvin)
    Which Headlights Shine Best: Halogen, HID or LED? | Angie's List
    Apr 2014
    The Monash Freeway
    Hi Guys,
    Are they the fog lights or daytime running lights? If fog lights, then you only use them in fog legally when no other cars are around you, so why do you if it “looks” cheap?
    Ben
    2015 Polo GTI & 2019 Golf R
    Apr 2013
    Pet hate - people driving with fog lights on when not needed (only surpassed by people who can’t stay in their own lane)
    Quote Originally Posted by Jimi View Post
    Another is when people use foglights at night with their headlights off... !!!!
    Oct 2013
    Buderim Qld
    Hi All, If you use white lights or even normal incandescent bulbs in fog the light dazzles you the driver especially on high beam, That is why most fog lights are yellow. I used to live in very fog prone areas in Tasmania so speak from experience.
    Fog lights done bother me one bit - what does bother me is the 3 separate cars i saw last night within a very short 5-10 min drive who were driving at night (7.45pm) completely oblivious to the fact they do not have their headlights on. Not even parker lights. I almost pulled out in front of one of them because they are almost completely invisible when in a dark coloured car.
    Assuming the fog light in the current Tiguan is a traditional filament bulb and not some new age LED or similar, and if it is indeed a H8 type bulb, then something like this is what you will want to get a nice white light and not have to worry about error codes.
    PHILIPS H8 Diamond Vision 5000K White Halogen Bulb | Blingwork Automotive Lighting
    Before buying anything, i would suggest you remove one of the bulbs and check that it is infact a H8 style bulb as there are many different shapes and sizes of bulbs.
