Results 1 to 10 of 12
Thread: Cheap Tiguan (compatible) wheels
    Oct 2015
    I’d like a cheap set of wheels and tyres for basic off-road driving.
    I’m hoping that there will be other vw vehicles that use the same stud and offset numbers as the current Tiguan/allspace, so I can buy a second hand set of 16’s to put tyres on.
    Please tell me I’m correct. Or feel free to recommend a cheap supplier of wheels that are suited.
    Cheers.
    Oct 2015
    Will mk1 Tiguan 16’s fit? Found a cheap set online.
    Not sure but I have heard that 16's won't clear your front brakes (you'd need to test fit to be sure).
    Also tyres from a mk1 Tig will be wrong size so you'll need to swap these off for something the correct profile (to keep speedo accurate).
    Aug 2018
    Adelaide Hills
    Quote Originally Posted by Simonr23 View Post
    That's what I did.
    Replaced rubber with some A/T tyres (225/70R16) - great stuff!
    Jun 2011
    I’ve got a cheap set of 16” 5x112 CSA Essen wheels that have a 215/65r16 Yokohama GO15 all terrains. They fit my Passat Alltrack quite well with no rubbing of note. Tiguan wheel arch is bigger than a Passat isn’t it?
    Oct 2015
    i ended up buying some wheels and tyres from bobjane. was just easier. i dont really like the rims, but theyre function over form.
    Cheap Tiguan (compatible) wheels-img_8901-jpg
    Nice! Tyres look the business!!!
    Just dug up Dougs pics (for reference) - some Gen1 16" wheels:
    Jun 2011
    What tyres and size did you get?
    Oct 2015
    17” rims, 225/65 pirelli scorpion all-terrain plus tyres.
    The brake calipers must be so close on the 16’s. I only have about 10mm clearance with these particular wheels.
