Results 1 to 8 of 8
Thread: Disable Boot Button on Key Fob?
    Aug 2021
    Hi,
    Is it possible to disable the open boot button on the keys using OBDeleven? I’ve had it accidentally open a few times.
    I’ve seen some information for Audi but I couldn’t find much for VW.
    Thanks
    Pacific Paradise QLD
    Never heard of it being done and dont know of anything in OBDEleven that will. Maybe this cover will prevent it as its a little less sensitive than the actual button. It also stops the button that opens the key from working unless fully pressed. I havent had either pocket work since I have used it
    Soft TPU Car Key Case Cover For Volkswagen VW Golf 7 MK7 Tiguan mk2 for Skoda Octavia 3 A7 Kodiaq 2017 2018 2019 2020|Key Case for Car| - AliExpress
    Jun 2007
    Sydney, Australia
    You can disable it on the Golf 7 so "may" work with a Tiguan.
    09-Cent. Elec
    Adaptation
    Access control - Direkter Auswurf des Heckdeckels
    Should read "Active" change to "not active"
    You may need to first enter a security code for this to work in 09-Cent. Elec.
    Flipper Dog
    Now - T-Roc 140TSI, Audi Q5 40TDI
    Past VWs- Golf 6, 7 and 7.5, Touareg 7L and 7P, Passat B5.5, Polo MK3, Polo MK4 and GTI
    Aug 2021
    Thats a not a bad solution, will have a look around for one. The key flipping out can be annoying too so two birds one stone.
    Cheers mate.
    Quote Originally Posted by Flipper Dog View Post
    09-Cent. Elec
    Adaptation
    Not in my 09 Module at all
    Quote Originally Posted by NSCaffeine View Post
    Cheers mate.
    I posted the link to the cheapest one and its quite good quality
    May 2023
    Finland
    I disabled it by doing this with ODIS. Sure will it work with VCDS
    Adaption
    09 Central Elec.->[VO]_ZV Heck->Direkter Auswurf des Heckdeckels.
    Change value from "active" to "not active" then confirm.
    Needs to have security code. I found that on Ross-tech website.
    This made it so i cannot open with fob, but i can close with fob.
    I revived this thread and registered a new account just for this comment for fellow VW heads. Have a Good Day
    Quote Originally Posted by MrZlicek View Post
    Adaption
    Is in the module in a Tiguan so able to be done. Prev instruction missed a step
