Can this be done for the Passat Alltrack Wolfsburg? Not a fan of the speedo incrementing by 10 after 80kmh. Rather the speedo above incrementing by 10 after 120kmh...
Printable View
Yes it can, I’ve changed to the R clocks on my Wolfsburg.
Ky
What is the coding for HBA in Obdeleven? Finally had a play today but haven't seen how to enable this. Also couldn't do the window close when raining as the Adaptation looks totally different. I did enable TMS, R dash (1-9 plus A-D) and turned off nag screen.
Thanks
Karl
Give this a go Karl
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
1. Fernlicht_assistent – Menuesteuerung Fernlichtassistent – Change to ‘Present’
2. Fernlicht_assistent – Erweiterte_Frenlichtsteuerung – Change to ‘AFS, FLA, Fernlicht ueber AFS’
Enter Coding
Byte 2 – Tick Bit 0 and Bit 1
Select Control Unit Front Sensor Driver Assist System (A5)
Enter Coding
Byte 21 – Tick Bit 5
Reboot Headunit. Option will now appear under ‘Light Settings’ and pushing the high beam stalk forward will reveal the symbol with an ‘A’ within it.
on the passat alltrack wolfy i think you need to change to this setting:
‘AFS, FLA, BCM-Fernlicht'
as mine was previously 'AFS, BCM-Fernlicht'. It seems it recognizes the LED headlgihts as Xenons as per this post.
Thanks everyone!
