yeah, I enabled the box but when I tried to enable the one in adaptions I just got function not available and it didn’t slow for a different speed limit also
Printable View
Just seen this
tempolimitassistent_carmenu
which means speed limit assistant car menu
dodnt seem to do anything tho
Does the sign recognition work in your model, or is it completely turned off? If it isn't enabled for the Arteon then you might have the same problem as the Passat owners have; i'm told the GPS data isn't the right type for Australia so it will throw a fault about 1 minute after the car starts, it relates to the lack of proper speed limit data from the GPS maps.
It does work (aside from the warning), but it's a little sketchy as most of Australia isn't road signed to any reasonable standard like other markets. This means you can pickup poorly positioned signs on adjacent roads/freeway offramps. Your car could start braking in the middle of the freeway because you're doing 100km/h and the offramp (which you're not on) has a 60 sign visible from the freeway.
W
Hi All
Did my first obd11 tweek via the app to keep my auto high beam on. It all worked just fine "Whoot". However there are just 4 other apps and i dont need any of them. Would like to turn on traffic signs and auto door lock , but can't translate from the rosstech type info on here. Any suggestions? Taking small baby steps....lol
Sent from my SM-G935F using Tapatalk
