Page 15 of 16 FirstFirst ... 513141516 LastLast
Results 141 to 150 of 155
Thread: Map updates
  1. #141
    Apr 2018
    Quote Originally Posted by Flipper Dog View Post
    I had a similar issue a while ago with the message "Error: no data available please insert a source with software or check the source". Turned out to be a download issue with the file not the SD card.
    My download missed some files so I retried another go, looked over the file size and numbers and noticed a slight difference.
    I now use a 3rd party download program as my internet speed is still trying to cope with Y2K.
    Will try again today then and re download on a different machine, i'll get back in a few hours.
    cheers
    Passat Alltrack Wolfsburg Edition My18
  2. #142
    Apr 2018
    Didn't work again, I ordered a new SD card and will use a download manager next week and try again.
    Thanks for the help guys.
  3. #143
    Pacific Paradise QLD
    Quote Originally Posted by Just_Westy View Post
    Weird Have never had one fail from the VW site, The Skoda Site or the link regardless of the card used. I have a 50Mbs NBN fibre connection and it takes about 3 hours to download
  4. #144
    Apr 2018
    I have used 2 different computers and have 50Mbs NBN as well so I'll change a few things and hope it works. It took 2 attempts last time to get it to work with a different SD card.
  5. #145
    R u using Winzip or what I use WINRAR
  6. #146
    Apr 2018
    7 zip that was on the VW site not sure if it is the culprit.
  7. #147
    Jul 2017
    Lalor, VIC
    My bad, i was ment to say updated my map*
  8. #148
    May 2020
    Oxley, Queensland
    hi all, my first post. Had finally managed to update the system after lots of tries. Sharing my experience and hope it would help people.
    From my experience, I used two different SD cards (class 10) of different brands (Sandisk and Lexar). It made no difference (both failed). I tried different formats (FAT32, exFAT and NTFS) using both Mac OS and Win 10, this made no difference (i.e. all failed). Tried WINRAR on Win 10 and RAR extractor on Mac, failed. Tried a USB, with all the above tricks, failed. Tried to access secret menu by holding Menu button on the unit, which allowed me to see folders and files, failed. Tried using either MIB1 or 2, failed. I was frustrated almost to the point of forking out $$$$ for a dealer, but sanity hadn't left me after weeks of ISO.
    What worked was using 7-ZIP on window to extract the file directly onto a USB (FAT32 format). Copied 2 folders and txt file to the root folder. It worked flawlessly. Took about an hour to update.
  9. #149
    Quote Originally Posted by passatB8 View Post
    Lot of effort and if using a MAC there's the problem straight up.
    Have never had a problem Format the card in FAT 32 (ALWAYS) d/load map to HDD, extract using winRAR, copy whole folder to SD card bung it in the car and wait 40 mins and finished
  10. #150
    There is a new map on the Skoda portal but you might need a valid VIN to download it it is Ver 88 but still has current from Nov 2019 but that one was 85
    Installed and working
    See this post for link to it courtesy Flipperdog
    Maps update
