Page 1 of 26 12311 ... LastLast
Results 1 to 10 of 252
Thread: Dynamic Light Assist
    Hi All,
    I have just enabled DLA for a B8 Passat.
    There seem to be a number of possibilities with respect to BCM and headlight range module combinations, so this is still under investigation...hoping this might be possible to achieve with just coding and adaption - keep watching this space.
    Dynamic Light Assist < Technical Glossary < Innovation & Technology < Volkswagen International
    Thanks to DR074 for the link to instructions here:
    Activate Dynamic Light Assist (DLA) - up to MY 2017 - VCDSSchweiz
    There is a VCP parameter set for Passat B8 with highline LED and A3 with Matrix LED but this is only required to change the light startup sequence (the headlight dance). It is possible to fully enable the feature with just coding and adaptation through VCDS.
    NOTE: if you have the older VCDS HEX-USB or HEX+CAN it is NOT able to see a module at address 4B. This is the address of the headlight control module in newer Tiguans.
    VCDS V2 interfaces and VCP can see and change settings in this module.
    Will update once I test OBD11.
    Feb 2013
    Perth, WA
    I am assuming most AU delivered B8 Passats with LED headlights would not have that headlight, or do most have them?
    Is this the full DLA or just HBA?
    Given you upload a different parameter set, will it count as flashing which may modify checksums in the control module, therefore potentially throwing a TD1 flag?
    Are there any VCP owners in Perth?
    Cheers.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
    This is full DLA - as far as I am aware. Please feel free to correct me if I'm wrong.
    I have no idea what Passats get what headlights sorry.
    A VCDS autoscan will list the LED LeiMo li. part numbers.
    With respect to TD1 to be honest I don't know the answer to that question. I will try and find out and report back.
    Feb 2013
    Perth, WA
    Hi All,
    In the B8 it requires the LED high headlights 7PP 941 572 AB.
    Unfortunately it requires the upload of a suitable parameter set using VCP, and some coding/adaptation changes, then basic settings.
    There look to be parameter sets for the following cars:
    A3 with headlight range controller 7P6907357D
    Passat B8 with headlight range controller 7P6907357C
    All of this information required for VCP owners is available in the VCP forums.
    If anyone is in Sydney and wants this enabled let me know.
    Outside of Sydney VCP owners check the English forum, let me know if you have any trouble with it. Just need to get the sequence right and it's all done in 15mins.
    Mine scan as 7PP 941 572 A (MY 17 206 Passat). So I guess they're different.
    Quote Originally Posted by Wynnston View Post
    What is the part number of your BCM?
    Feb 2013
    Perth, WA
    5Q0 937 086 BH (BCM PQ37BOSCH) 032 0222
    ASAM Dataset: EV_BodyControlModul1UDSBosc 017002
    Headlight Range Control is HW: 7P6 907 357 B
    *** This is probably easier for you ****
    Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
    Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
    Component: AFS-ECU H01 0120
    Revision: -------- Serial number: --------------
    Coding: 03A603000F210200
    Shop #: WSC 05311 000 08XXX
    ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
    ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
    VCID: 3F8DA667A6BDA0BEB3-806A
    Led Headlamp Powermodule Left:
    Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
    Component: LED LeiMo li. H09 0003
    Coding: E02400
    Led Headlamp Powermodule Right:
    Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
    Component: LED LeiMo re. H09 0003
    Coding: E02400
    Left Headlamp Power Output Stage:
    Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
    Component: LeiMo links H02 0003
    Coding: E02400
    Right Headlamp Power Output Stage:
    Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
    Component: LeiMo rechts H02 0003
    Coding: E02400
    Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
    Part No SW: 5Q0 937 086 BH HW: 5Q0 937 086 BH
    Component: BCM PQ37BOSCH 032 0222
    Revision: -------- Serial number: 86581108160XXX
    Shop #: WSC 00015 115 08XXX
    ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
    ROD: EV_BCMBOSCH_017_VW27.rod
    VCID: 0109609F90C9164E85-8054
    Should work, but you'll need VCP.
    Same BCM as the one I did this morning.
    LED is a slightly different revision but I don't think that should preclude the feature being activated.
    Feb 2013
    Perth, WA
    Hi All,
    I think you need to know the PN of the actual headlight unit. One has on/off shutters and the other has rollers (I think)
    Ok so that part is actually the LED ballast, so that looks like it doesn't describe what type of LED headlamp assembly is in front of it...
    It might be easier to tell from the PR codes maybe.
    Do you know where the list of PR codes for all the parts installed in your car is located?
    It used to be in the wheel well but when I looked in a Golf 7.5 the other night it wasn't there so I assume it is in the car's service book or manual.
    Sep 2017
    Hi Wynnston,
    The above worked on my 206, DLA is working on my car. Used OBD11
    Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
    Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
    Previous - Passat 206TSI MY17 - Night Blue
