Page 24 of 26 FirstFirst ... 142223242526 LastLast
Results 231 to 240 of 252
Thread: Dynamic Light Assist
  1. #231
    Apr 2020
    france
    Odis AFS_MDF
    Quote Originally Posted by dArK5HaD0w View Post
    Finally got some good news to report - the final piece to the puzzle, the AFS_MDF data file, was successfully loaded, via ODIS, into the 4B module and the SLA (Skoda's version of DLA) functionality is now fully operational.
    No errors. wooOoot
    I went for a quick test drive and its certainly doing the fancy masking with the auto high beams, as expected.
    A BIG BIG thanks to Kamold and Magnus with their assistance, and patience in sourcing the parameter file.
    Hi, I'm very interesting of activating the MDF on my Passat B8 2017, I already set up everithing but my DLA is not working propely, I'm equiped with ODIS (but not VCP), here you say that you successufully download AFS_MDF file in 4B module with ODIS, could you please give more information about it ?
    many thanks for your Help
    The frenchy
  2. #232
    You'll need the Passat parameter file, not Superb.
    Unfortunately it's available in VCP as a sec file not XML so you can't apply with ODIS.
    If you have odis online access it's possible to use a technique to obtain the parameter file.
    Sent from my SM-G960F using Tapatalk
  3. #233
    Apr 2020
    france
    ok... never mind I must find someone with VCP who can Help !
    maybe one of you come to France for holidays
    thank you for replying..
  4. #234
    Apr 2020
    france
    Cool
    Hi All !
    I'm back again...
    has anybody ever tried to convert an Odis-e XML dataset file to a VCP one ?
    GitHub - jilleb/odis2vcp: Converter for ODIS XML Datasets to VCP XML format
    I found a converter and I am really curious to know !
    the problem is that I don't have any xml files. I need to upload the AFS_WITH_MDF dataset in the 4B controler.
    does anybody have this xml file, even from superbe, I know dArK5HaD0w does it into a SKODA.
    Thanks for helping
  5. #235
    Jul 2010
    Quote Originally Posted by jgazengel View Post
    Thanks for helping
    Hey - PM me ur email address and I can send u the Superb 4B parameter file for the AFS_with_MDF.
  6. #236
    Apr 2020
    france
    Hi dArK5HaD0w
    I sent you a Mp with my mail.
    many thanks, I was desparating waiting for an xml file to see how it 's formated.
    all the best to you
  7. #237
    Apr 2020
    france
    Bixenon xml file into Leds headlamp...
    the facts :
    - I checked the reference of my 4B controler, is the same as the xml file
    - I baked up all the 4B coding before transfering the file you sent me.
    - I transfered the file with Odis E, all goes fine but...
    - I have a defect into the 4B module:
    --> event 5081F1[5276145] (SAE code C1081F1) Left HeadLamd power output stage incorectly coded
    --> event 5082F1[5276401] (SAE code C1082F1) Right HeadLamd power output stage incorectly coded
    the shame is that I forget to backup the sub module 6D coding of each side !
    defect in sub Module:
    00013[19] SAEC119F00, projector variant not plausible(SOA mismatch)
    does anybody have an idea where I can find back the right coding of this two sub 4B controller for Led Headlamps ?
  8. #238
    Apr 2020
    france
    I Have try to cod back again the power output stage (D6 and D7) but when I start coding I receive a message telling it was not possible to "read the controller coding !", all bytes =0 I
    I tried to code a value I found on a scan on a forum, HEX "E02400" but rejected ! It feel like the controler is not codable anymore...
    maybe if I transfert the right xml file for led Headlamp it reactivate the right coding ??
    waiting for any suggestion ... I'm out of ideas !
    Ho My god I even don't have high beam anymore !
  9. #239
    As I said you need the correct parameter file for your vehicle.
    This will then also correct the sub modules.
    If you cant get the right file you will need to visit a dealer and have them perform software configuration online with ODIS.
  10. #240
    Apr 2020
    france
    thank you Kamold,
    this is a bit comforting...
    does someone can tell me where to find some xml files ? I've drained all google post without success..
    dArK5HaD0w how did you get yours ?
