Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Coolant Topup Options
    Jan 2017
    I've had the same problem last year... turned out the water pump was leaking and was replaced under warranty. I topped up with distilled water prior to my appointment with the dealer.
    Jan 2010
    Burwood, NSW
    Quote Originally Posted by Johnte View Post
    Hi all,
    I'm scheduled to the service centre next week but my coolant is extremely low and I would like to do a top up before seeing the service centre.
    Can I confirm that any red coolant from supercheap auto will be fine?
    I entered my license plate on their website and one is recommended with total flush and the other doesn't state that a flush is needed. I assume I use the non flush required one? The brand in Nulon for reference.
    I have a 2015 140TDI Wagon.
    TIA
    Check and make sure your water pump is not leaking.
    As you shouldn't need a top-up at all as mine have not even moved at all
    after so many car service and mine is 122k now.
    Mar 2017
    Definitely see if water pump is the issue. I'm getting my water pump replaced in the 206TSI under warranty next week as was leaving nice coolant puddles all over the place. De-mineralised water did the trick as a temporary small top up.
    VW Passat 206TSI Wagon - Lapiz Blue - Sunroof
    VW Polo GTI - Black Pearl - Sunroof
