Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 52
Thread: Camp Alltrack 2.0
  1. #41
    Feb 2015
    Mine failed at 35k 2 years in Wolfsberg Alltrack Diesel - replaced under warranty
    Passat Wolfsburg 2017
  2. #42
    Jan 2010
    Burwood, NSW
    Quote Originally Posted by Foxpuppet View Post
    Ours is a MY17 and warranty has expired as of Feb last year. before it expired we had the car in and checked over for anything that might have been amiss but it was only on around 60k at that stage.
    Now you can take it to any VW specialist to get it done. I will take mine to Paul at 2/2 Dunlop st. South Strathfield when it is out of warranty.
  3. #43
    Jan 2010
    Burwood, NSW
    Quote Originally Posted by Skoda729 View Post
    Wow, 35k that early.
  4. #44
    Apr 2010
    Mine failed at 45K.
    VW replaced under warranty, eventhough the warranty had expired 4 weeks earlier.
    Must have been a bad batch of water pumps, by the sounds of it.
    MY17 Passat Alltrack Wolfsburg, Indium Grey, Sunroof
  5. #45
    Jun 2018
    Waranga Shores, Victoria
    That looks awesome, they really need to offer them with more lift and smaller wheels. There’s no point to 18” wheels with low profile on a vehicle like this, not sure why they thought 19” on the Wolfsburg was a good idea.
    I agree about the wheel size on Wolfies. After reading this thread and others, I have just replaced the 19" wheels fitted to mine with a set of used OEM 17x7 B8 Passat rims with 215/55R17 tyres which I found on ebay. I'm very happy with the result. Better ride, less bump steer, less jittery steering. I'll probably replace these tyres with 225/66R17's when these are worn out. The rolling diameter would then equal the 19" original tyres, give a slight increase in ground clearance, and perhaps even better ride.
    Having read the above threads, I might have been even happier with 16" rims. Perhaps in the next life.
  6. #46
    Blackburn South, Victoria
    Mine is just coming up to 30k km... i do have eric 5yr extended warranty...
    Quote Originally Posted by ToomanyVWs View Post
    225/60R16 98Y is available in the Pirelli Cinturato P7 (Which is the same 19" tyre fitted to the wolfy and has the same load and speed index, so insurance should be fine as its the same rolling diameter). Might have issues fitting over the brakes?
    2008 MY09 Ibis White Audi S5 Manual SOLD!
    2017 MY18 Manganese Grey VW Passat Alltrack Wolfsburg SOLD!
    2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
    2023 MY23 Nevada White Cupra Formentor VZx
  7. #47
    Jun 2011
    Damn, just had the all track in finally to see if we could fit the 16” wheels I had from the old car and it’s a no go. Needs more clearance and offset to work.
  8. #48
    Jun 2011
    New roof box got mounted though, pretty happy with it.
  9. #49
    Jun 2011
    Using it. Drove through 15cms of snow for a fe km and had a ball!
  10. #50
    Aug 2023
    Bulimba, QLD
    Hey Foxuppet,
    Did you ever put 17"'s and larger tyres on your B8 in the end?
    I am looking to do something simlar to what you did on your 1.0 Build. But I am aslo looking for a 1.5inch lift kit.
