Results 1 to 7 of 7
Thread: B8 tsi sedan suspension replacement
    Jan 2013
    Hi
    I wonder if someone can recommend suspension for b8 pasaat. Not looking for lowering car...just making ride more comfortable...
    Sent from my SM-G986B using Tapatalk
    2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
    A higher quality strut (or even new OEM struts considering your car is now approx 7 years old) will help. If you go aftermarket you cant really go past Bilstein. Sparesbox have a good range of Bilstein (and other) struts, worth a look.
    Note stock struts are Sachs brand and you will also see these on the Sparesbox site. Meyle are another OEM brand. KYB are aftermarket and Japanese - also good.
    Shock Absorbers & Coil Springs | Sparesbox
    2017 Ford Fiesta ST
    Jan 2013
    Hi
    Thanks, will check it...
    Btw, this passat is 2017 model
    Quote Originally Posted by saint70 View Post
    Hi
    Ah ok - I went searching for a 2014 model based off the info in your signature. Either way, im sure you will find some options for your 2017 model.
    2017 Ford Fiesta ST
    Jan 2013
    Hi
    Waiting for quote for KW suspensions.. i will let you know once i got answers.
    Oct 2016
    Melbourne, Vic
    I would expect that most aftermarket suspension would be firmer than stock. We have a 2018 Passat with R Line suspension (so lowered and maybe a bit firmer although I am not sure about the firmness) and we don't find it uncomfortable. Depends what changes you are hoping to make and what your definition of comfortable is. Tyres and also tyre pressures can also have a bearing on what we perceive as comfortable
    Jan 2013
    Quote Originally Posted by hulbyw View Post
    Thanks for good tip.
    A.
