Quote Originally Posted by Old Navman View Post
Copy. Although my, limited (thank God) experience with Oz VW spares is if you need for example a PCV valve diaphragm you'd probably need to buy the whole rocker cover. I doubt then they'd have just the locking tab on it's own but ... I will check it out.
Yes for sure, they believe in replacing the car or part as a minimum if you get some work done.
Plastic bits should be fine
