Results 1 to 10 of 16
Thread: Park assist pla 1.5 anybody?
    Mar 2015
    perth wa
    Hi all I'm having trouble with my park assist install ,I have wired everything up and up to the coding stage .I have 1t0 919 475 m module and vcds can read it but cant do a single code it says -this appears to be an uninitialized control module click yes no or cancel (yes is use default values of 12345 123 12345) I click yes and I get -coding rejected error 31 ?? Has anybody successfully installed pla 1.5 ?
    Sent from my SM-G935F using Tapatalk
    What coding are you trying to apply? Just try putting in the most basic string you can (whatever is closest to 00000000 or whatever) and apply. Then try and change to your correct settings.
    Mar 2015
    perth wa
    Just trying to code new module for ops,rvc,automatic transmission stuff like that but wont accept a single code .strange that it can communicate with the module and when I swap over back to standard ops module it can code to what ever on default values.also the new park assist button works and shows in the cluster screen so I was thinking maybe my abs module is too old and doesn't support pla 1.5??
    Mar 2015
    perth wa
    kit like this one
    Pacific Paradise QLD
    Ive got park assist in my car and have used it once in 5 years.
    I found it wasnt as accurate as it was supposed to be and find it quicker to use my mirrors and rear view camera.
    Even the lines on the reversing camera arent as accurate as they should be. If I backed up till the red line was on a cars bumper behind me I would have hit it.
    Eyes and mirrors for me Im afraid.
    Mar 2015
    perth wa
    I'm hearing you but I still like the challenge and I think it's a cool feature even if I don't use it ,anyway I'm kind of committed my car is in bits at the moment
    Can you post a full autoscan?
    Might need to upgrade to a b7 abs like you have to for acc
    Mar 2015
    perth wa
    maybe I need a older PLA module like the 1t0 919 475 G or H first of the PLA 1.5 ? OR even the 1t0 919 475 B which is PLA 1.0 out of 08 passats? mine was just the original 8 sensor with no ops or park assist. anyway here are my faults.
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 3C0 907 115 T HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0020
    Revision: 5BH16--- Serial number: VWZCZ000000000
    Coding: 0404004319070160
    Shop #: WSC 00028 028 00001
    VCID: 3169F346A88957962BD-8064
    1 Fault Found:
    008577 - Performance Malfunction in Cooling System
    P2181 - 008 -
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 126675 km
    Time Indication: 0
    Date: 2001.14.12
    Time: 10:24:47
    Freeze Frame:
    RPM: 1770 /min
    Load: 39.6 %
    Speed: 89.0 km/h
    Temperature: 63.0°C
    Temperature: 27.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.097 V
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
    Component: J104 C4 440 V2 0003
    Revision: --020--- Serial number: 00000776413240
    Coding: 0003414
    VCID: 1F4D05FECE1DD1E68D9-804A
    No fault code found.
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 5K0 907 044 ES HW: 5K0 907 044 ES
    Component: Climatronic H18 1112
    Revision: 00003001
    Coding: 0000000002
    Shop #: WSC 12345 123 12345
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_ClimaAutoBasis_SE36.rod
    VCID: 800FE6821BA38E1E143-80D5
    1 Fault Found:
    13701888 - Function Restriction due to Faults in Other Modules
    U1113 00 [009] - -
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 16
    Reset counter: 97
    Mileage: 135209 km
    Date: 2009.14.02
    Time: 16:53:31
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 01000005275691
    Coding: E4848A0700041A00470F00000F000000000958415C00010000 0000000000
    VCID: 71E93346680917966BD-8024
    Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer 201007 022 0601
    Coding: 00046997
    Shop #: WSC 00028
    Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
    Component: RLS 301007 046 0204
    Coding: 00208933
    Shop #: WSC 00028
    Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
    Part No SW: 1T0 919 475 M HW: 1T0 919 475
    Component: PARKHILFE PLA H07 0113
    Revision: -------- Serial number: 50631124805910
    Coding: 000000
    Shop #: WSC 00000 000 00000
    VCID: 4581B796CC01EB36E75-8010
    1 Fault Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 97
    Mileage: 135209 km
    Time Indication: 0
    Date: 2009.14.02
    Time: 16:53:30
    Freeze Frame:
    Temperature: 37.0°C
    Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
    Part No SW: 3C0 953 549 AH HW: 3C0 953 549 AH
    Component: J0527 0030
    Revision: 00035000 Serial number: 3C0953507
    Coding: 0001411
    VCID: 72EB3C4A6D0F2C8E927-8027
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments (J285) Labels: None
    Part No SW: 35D 920 880 A HW: 35D 920 880 A
    Component: KOMBI H01 0505
    Serial number: 00000000000000
    Coding: 140B01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
    ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
    VCID: 285F1E225353165EFC3-807D
    Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
    Part No SW: 3C0 907 530 N HW: 3C0 907 951
    Component: J533 Gateway H14 0172
    Revision: H14 Serial number: 1091G1112300F0
    Coding: FDA07F06400602001003
    VCID: 2C57E2328FAB3A7E18B-8079
    1 Fault Found:
    02830 - CAN-Extended Separator for Driver Assistance Systems
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 1
    Fault Frequency: 15
    Reset counter: 97
    Mileage: 135209 km
    Time Indication: 0
    Date: 2009.14.02
    Time: 16:53:31
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
    Component: IMMO 042 0383
    Revision: 00042000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 3979CB6670F99FD693D-806C
    Subsystem 1 - Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 D HW: 1T0 035 680 A
    Component: RNS-MID H04 3810
    Revision: AB001001 Serial number: VWZ6Z7G5261003
    Coding: 00000442040000900000
    VCID: 2F6DF53E7EBD41663D9-807A
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1132
    Revision: 32008001 Serial number: 00000529679001
    Coding: 0000757
    VCID: 3B75D16E7AC5ADC6811-806E
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.135 H08 1901
    VCID: 3663C05A41E770AE7EF-8063
    1 Fault Found:
    03075 - Parallel Parking Assistance Control Module (J791)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Mileage: 135200 km
    Temperature: 43.0°C
    Voltage: 12.90 V
    Voltage: 12.70 V
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 042 0472
    Coding: 18910A0001860E7600001C1FE0085F0A007800
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1132
    Revision: 32008001 Serial number: 00000061379001
    Coding: 0000756
    VCID: 3C77D2727FCBAAFE88B-8069
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
    Component: J540 EPB3 VW-09393 0009
    Revision: 008 Serial number: 00000000220940
    Coding: 0000057
    VCID: 29591B2680592F56E3D-807C
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    Aug 2007
    Maybe you need the passat version. 1T0 might not work.. try a 3AA like 3AA 919 475 L which is what i have with park assist on a 2013 b7 passat.
