Results 1 to 7 of 7
Thread: Occasional false neutral on Reverse - mechatronics unit needs replacing?
    Sep 2010
    On my R36, reverse gear takes a few seconds to engage, and on occasion it will do the clunk, clunk, clunk and then cause a false neutral. If this happens, turning the car off/on remedies the issue and I am able to engage reverse again. I tried a DSG reset using VCDS, but still the same.
    All forward gears shift quick and smoothly with no clunks.
    I am wondering what else it could be - clutch packs? I'm keen to get this remedied at the next service. I've had people beep/rage at me because I took so long to reverse into a parking spot.
    This is the only issue I have with the car, which is great, considering that I am nearing 240,000km on the clock.
    '18 MY18.5 MK3.5 Octavia vRS245
    Previous - 2015 MY16 MK7 R, 2010 MY10 R36 DSG, 2010 MK6 Golf GTI DSG // APR Stage 2, 2006 MK5 Jetta TFSI DSG // Revo Stage 2, 2006 MK5 Golf GTI Manual
    It is possibly clutches at that age, but could be a mechatronics issue. You have the AL or AM rev mecha which are known to be more reliable than earlier revisions based on the previous Motorola processor.
    When you say DSG reset, did you perform basic settings per the Ross Tech wiki?
    6-Speed Direct Shift Gearbox (DSG/02E) - Ross-Tech Wiki
    Would consider replacing the clutchpacks at that age unless there is a clear sign that it is a mecha issue (any fault codes logged?)
    Jan 2016
    Engadine, NSW
    I have the exact same issue occurring in my 2010 125TDI Highline however I have only 101,000kms on the clock. My rectification is also the same in that turning the engine off the on restores gearbox back.
    Not sure if this helps to pin point weather it is a mecha problem or not but I get the following fault code - P2711 - Unexpected Mechanical Gear Disengagement
    2010 VW Passat 125TDI Highline MY10.5 6sp DSG Wagon - Dynaudio RNS510, Park Assist, 18’ Chicago Wheels
    2012 VW Touareg V6 TDI MY13 7P 8sp DSG 4MOTION - Sports Package, Dynadio sound, Area View, Driver Assist & Pano Sunroof
    Previous - 2016 VW Golf MK7 R DSG Auto - Lapiz blue & 2011 VW Golf MK6 R DSG Auto
    Quote Originally Posted by mrkhna View Post
    That sounds more likely a mechatronics issue (K1 or K2 main clutch solenoid is not holding clamp pressure).
    Jan 2016
    Engadine, NSW
    Thanks J...
    any idea of whether or not this issue may have been part of a recall overseas or locally? or is this something that can fail from one vehicle over another? Also am I looking at big $$$ for fix?
    Not a recall issue.
    Solenoids can fail.
    New mechatronics from VW is $2700ex. Plus fluid, labor.
    You can buy the solenoids on their own.
    Jul 2011
    If never been done id recommend clutch pack and mechatronics new oil and filter good for another 10years
