Hi Matt,
If you search my build thread you will see that I’ve had some similar issues to you. One of my parking sensors was changed under “warranty” but the cheapskate dealer put a non-genuine one in. Didn’t fix the issue – sensors continuously beeping. Ultimately we pulled the front bar and found wiring loom patched up after previous accident damage(?) and we replaced the loom with a new one, which I think was $400 plus.
I also fitted a factory lowline RVC, which my mechanic fitted – quite a fiddly job as a lot of trim has to be removed and pushing the wiring through the rubber tubing near the tailgate is difficult especially if you have a power tailgate.
I’ve purchased a Dynaudio system to retrofit. It wasn’t cheap but did include the complete door cards to make it look like a factory fit. Unfortunately some of the locating brackets in the door cards have broken, which means sourcing a damaged card so that we can cut and plastic weld the brackets to the Dynaudio door cards. My guy also insists we buy a new set of Christmas clips for the job – I don’t want to introduce any new rattles to the interior.
Regarding shocks, I installed new Bilstein B8s (don’t use B6s) with new top mounts on the standard springs. The ride is marginally firmer but a lot more controlled than my standard shocks, which were shot after 130K.
Paul
Biscay Blue MY10.5 Passat R36 Wagon
Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC with Front Assist, RVC, BT 9w7, Factory Tint and Factory Towbar
Night Blue MY15.5 Golf GTI Performance
Options: Black Vienna Leather, DAP II, Panoramic Sunroof and Voice Control (every box ticked.)
