Results 1 to 6 of 6
Thread: Axz Pcv
    Jan 2015
    Melb
    Axz Pcv
    The Pcv has started to leak on the 3.2 vr6. Where’s the best place to get the diaphragm?
    What else will I need? Rocker cover gasket, inlet gasket, something to clean the inlet valves?
    Mornington Peninsula, VIC
    On my 3.6 I used the RKX kit, which looked pretty nicely made.
    Valve cover gasket, intake manifold gaskets, I am not sure how the 3.2's single-piece manifold is removed, but on mine, the lower injectors pulled out of the head, so be careful.
    I did the walnut blasting later on, but if it needs doing, do it at the same time would save a bunch of time.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Jan 2015
    Melb
    Thanks. I sent them an email. It looks like they have the Pcv but I might need to find the inlet/ rocker cover gaskets separately as they didn’t include them? It’s probably not a us market engine.
    Oct 2017
    VIC
    RKX kit seem to be the most recommended on this forum, it has all the gaskets/diaphragms you need for the job (on 3.2lt AXZ engine as well)
    Also see related post HERE.
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 398K ... and still going
    Jan 2015
    Melb
    Thanks for the tips. I did this on Sunday with the rkx diaphragm. It’s a fairly big job with the one piece manifold.
    Oct 2017
    VIC
    Quote Originally Posted by Passat my07 View Post
    yes, I can definitely vouch for that.
