Results 1 to 10 of 12
Thread: MY13 Passat throwing multiple errors
    Sunshine coast
    My MY13 passat has started to throw a lot of errors. Initially they were intermittent, but now they are present all the time. Since there are multiple unrelated errors I'm suspecting either a wiring or gateway issue?
    Any ideas to where to start looking?
    Code:
    Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
       Part No SW: 06J 906 027 DE    HW: 06J 907 309 B
       Component: MED17.5.2        05 5359
       Revision: PAH04---    Serial number: VWZCZ000000000
       Coding: 0404000C24070160
       Shop #: WSC 40139 959 131616
       VCID: 71C70889681165C758-8025
    1 Fault Found:
    053271 - Please Check Fault Codes in Control Module for ABS Brakes
                   U1017 - 015 -
                 Freeze Frame:
                        Fault Status: 01101111
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 207312 km
                        Time Indication: 0
                        Date: 2014.07.04
                        Time: 10:24:01
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: 96.0∞C
                        Temperature: 66.0∞C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 11.938 V
    Readiness: 1110 0101
    Address 02: Auto Trans        Labels: 0AM-927-769.clb
       Part No SW: 0AM 300 058 Q    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 6563
       Revision: 00043014    Serial number: CU501511237286
       Coding: 0000020
       Shop #: WSC 01049 002 1048576
       VCID: 3FA39EB16EC5C3B79E-806B
    1 Fault Found:
    006279 - Wheel-Speed Signal from ABS Control Module
                   P1887 - 000 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 0
                        Fault Frequency: 2
                        Reset counter: 10
                        Mileage: 207312 km
                        Time Indication: 0
                        Date: 2014.07.04
                        Time: 10:24:10
    Address 03: ABS Brakes        Labels: 3AA-614-109.clb
       Part No SW: 3AA 614 109 BK    HW: 3AA 614 109 BK
       Component: J104   C2 450M VD0B 0024
       Revision: --H07---    Serial number: 00000005930578
       Coding: 0001914
       Shop #: WSC 05311 000 00000
       VCID: 77D3369106753BF796-8023
    2 Faults Found:
    03842 - RPM Sensor Rear Right: Incorrect Signal
                000 - -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 11
                        Mileage: 207312 km
                        Time Indication: 0
                        Date: 2014.07.04
                        Time: 10:24:20
                 Freeze Frame:
                        Speed: 0.0 km/h
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 12.00 V
                        Bin. Bits: 00011111
                        Count: 157
                        Hex Value: 0x0000
    01325 - Control Module for Tire Pressure Monitoring (J502)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 11
                        Mileage: 207312 km
                        Time Indication: 0
                        Date: 2014.07.04
                        Time: 10:24:30
                 Freeze Frame:
                        Speed: 0.0 km/h
                        Hex Value: 0x0000
                        Voltage: 12.00 V
                        Bin. Bits: 00011111
                        Count: 191
                        Hex Value: 0x0000
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56261216601722
       Coding: 349106
       Shop #: WSC 99999 1023 2097151
       ASAM Dataset: EV_EPHVA2C000000000 002008
       ROD: EV_EPHVA2C000000000.rod
       VCID: 44A9915DCF23A06FC3-8011
    1 Fault Found:
    13637397 - Databus
              U1123 00 [009] - Received Error Message
              [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 10
                        Reset counter: 11
                        Mileage: 206241 km
                        Date: 2020.01.25
                        Time: 10:37:31
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         045 0400
       Revision: 00045000    Serial number: VWZCZ000000000
       Shop #: WSC 40139 959 99896
       VCID: 76CD3B95017F42FF8D-8023
       Subsystem 1 - Part No: 3C0 905 861 J
       Component:    ELV          029 0380
       3C0905861J     ELV          029 0380
    1 Fault Found:
    02829 - Enabling Steering Column Lock from Steering Wheel Electronics
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 206219 km
                        Time Indication: 0
                        Date: 2014.06.17
                        Time: 09:59:02
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 195    3305
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: 3753F69146F5FBF756-8063
    1 Fault Found:
    01316 - ABS Control Module
                013 - Check DTC Memory - MIL ON
                 Freeze Frame:
                        Fault Status: 11101101
                        Fault Priority: 3
                        Fault Frequency: 9
                        Reset counter: 11
                        Mileage: 207312 km
                        Time Indication: 0
                        Date: 2014.07.04
                        Time: 10:24:20
                 Freeze Frame:
                        Voltage: 12.00 V
                            DD
                        Temperature: 57.0∞C
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Speed: 0.0 km/h
                        Count: 0
    Address 53: Parking Brake        Labels: 3AA-907-801.clb
       Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
       Component: J540 EPB4  VW-86594 0010
       Revision:   H19       Serial number: 00000000310424
       Coding: 0022157
       VCID: 364DFB9541FF02FF4D-8063
    1 Fault Found:
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 2
                        Fault Frequency: 59
                        Reset counter: 11
                        Mileage: 206241 km
                        Time Indication: 0
                        Date: 2014.06.17
                        Time: 10:37:32
                 Freeze Frame:
                        Voltage: 13.90 V
                        Count: 105
                        Speed: 82.0 km/h
                        Hex Value: 0x1268
                        Hex Value: 0x8004
                        Hex Value: 0x0101
    132TSI Tiguan Allspace
    Sunshine coast
    A few additional error codes that I forgot to include:
    Code:
       Coding: 0000020
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 53
                        Reset counter: 10
                        Mileage: 206241 km
                        Time Indication: 0
                        Date: 2014.06.17
                        Time: 10:37:32
       Coding: 0001914
    7 Faults Found:
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
                014 - Defective - Intermittent
                 Freeze Frame:
                        Fault Status: 00101110
                        Fault Priority: 3
                        Fault Frequency: 9
                        Reset counter: 36
                        Mileage: 205396 km
                        Time Indication: 0
                        Date: 2014.05.24
                        Time: 10:52:52
                 Freeze Frame:
                        Speed: 97.0 km/h
                        Hex Value: 0x0000
                        Voltage: 12.75 V
                        Bin. Bits: 00011111
                        Count: 163
                        Hex Value: 0x0000
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 9
                        Reset counter: 36
                        Mileage: 205396 km
                        Time Indication: 0
                        Date: 2014.05.24
                        Time: 10:52:52
                 Freeze Frame:
                        Speed: 97.0 km/h
                        Hex Value: 0x0000
                        Voltage: 12.75 V
                        Bin. Bits: 00011111
                        Count: 163
                        Hex Value: 0x0000
    Rear right wheel speed sensor.
    Clean it check wiring then replace it.
    All the codes point to it.
    Sunshine coast
    Thx! Looks like the wheel and possible the calliper needs to come off to access it?
    Edit: found this youtube video showing the exact same problem as I've got; YouTube
    Sydney,NSW
    Any chance I can borrow your VCDS please?
    Sunshine coast
    Are you at the sunshine coast?
    Sydney,NSW
    Sorry Sydney..but can Xpress post back if it’s ok?
    Pacific Paradise QLD
    Quote Originally Posted by cru22z View Post
    You can buy one here VCDS | Product categories | Ross-Tech
    Sunshine coast
    Looks like the sensor is busted, it's reading 0km/h. Cabling looks ok. Part number is WHT003858, but I believe 1K0 927 808 is an equivalent replacement, which can be found cheaply online.
    Sunshine coast
    Put in the new sensor, but it's still reading 0km/h. I can't see anything bad with the cable on visual inspection, but I guess it's the next thing to try to replace.
    Edit: tried the sensor on the other side, the cheap replacement sensor I got off ebay is faulty.
