Wagon/sedan rear doors are a different shape.
Vent illumination you tap into the light switch so that you get dimming via the dimmer dial.
Printable View
Cheers guys!
Have procured the front door cars + vents + vent loom if I remove it all. Just waiting for better weather as it's extremely muddy where the car is.
Need to source rear wagon doors, figure that having the fronts alone will make it easier since they're in good condition.
I'll also have the B7 Passat Shifter surround which I can swap over, so that's nice.
Anyone swapped the rear vents across? One of mine is broken (it seems it was a family car before my ownership)
Latest update:
DQ500
I know this is going back a while but I was browsing through your mods and come to a conclusion that even if I retired I wouldn't have enough time to do all those however ... incidently I need to remove the shifter knob & center console to install a new coffee cup holder box. So, I want to make sure I know how to do it before stuff it up. Do you just pull & hold the small button out (on LHS of the shifter) and pull the shifter knob up with a bit of force?
Have a look at a few YouTube videos best way to see how it's attached
Sent from my SM-G960F using Tapatalk
It is the same.
Just that a (moving) picture paints a thousand words.
I can describe it but it's much easier to see from a complete video.
3C8 920 881
Unicorn.
