And what does everyone use on their racks?
Printable View
Sorry for the late reply on this thread but just stepping back a touch. In relation to your query regarding the tyre pressure monitoring coming on, 36psi is too low. You should be up around the 39-41psi range. I know when mine get down to this range that the warning comes up on my display telling me to check tyre pressures. Try putting some more pressure in them and see what happens. Also, what tyre pressure mode are you in. I think there is two modes depending on the weight you are carrying in your car.
Thanks snerlo I will give that a try, and report back. cheers!
I'm in light load conditions as mostly just me or one passenger as well.
Snerlo to the rescue! Set the tyres to 40 PSI today when filling with BP ultimate (including the spare, which had dropped from 36 to 32, and no more check tyre pressure alarm! Thanks Snerlo!
Cheers,
Chris
2008 R36 Reflex Silver Wagon
No probs mate. Always helps when someone has been there before.
Good work checking your spare. I was pulling my hair out over a TPMS warning on the dash for weeks. Tyres were at 40 psi on every gauge I tested with. Turns out the spare was 30 psi and setting it off
