Results 1 to 8 of 8
Thread: DSG 7 speed oil change
    Oct 2013
    Adelaide, Southside
    Lightbulb DSG 7 speed oil change
    Here is how to change the gear oil. It's not a hard job or even time consuming. VW says it's filled for life & provides no service intervals. This is not the Mechatronics unit which is stand alone sealed unit.
    Oil type: VW's own or these alternatives which meet the same specifications,
    Fuchs Titan Sintofuild FESAE 75W or Liqui Moly Hochleistungs Getriebeol GL 4+ (GL4/GL5) SAE75 W-90
    Volume: 1.8ltrs
    Tools needed: 10mm allen key, funnel, 14mm tubing, container for oil (2 ltrs), gloves & a rag for clean up
    DSG 7 speed oil change-20180511_111128-jpg
    Time: Allow to drain thoroughly prior to filling. I had lunch while it drained, about 1 hour. Actual physical work would be about 30 minutes.
    Firstly locate the breather cap on the gearbox access plate where directly below the battery. Poke your arm between air intake, firewall & battery bend your wrist to the right & you should feel the round cap. Wipe around with your rag ensuring a clean surface. The cap just pulls off.
    DSG 7 speed oil change-20180511_112712-jpg
    DSG 7 speed oil change-20180511_131719-jpg DSG 7 speed oil change-20180511_112351-jpgDSG 7 speed oil change-20180511_130520-jpg
    Ensure your car is on a flat level surface, locate the drain plug on the underside just behind where a join is toward the rear (underside). If looking from the passenger side it's just aft two bolts facing you in about the middle. Identifiable by a 10mm allen key plug. See pic.
    DSG 7 speed oil change-20180511_104847-jpg
    Place your container directly under the drain plug, undo the plug in clockwise directly (it's not too tight, only 30nm). Allow oil to drain until no more drips.
    DSG 7 speed oil change-20180511_105248-jpg
    Once drained, fit drain plug tightening to 30nm only.
    Connect your hose to the base of the funnel. I dipped a hose end in hot water to soften. Fit the other end of the hose to breather on gearbox. It wiggles on easily enough. If necessary heat that end too.
    DSG 7 speed oil change-20180511_112351-jpgDSG 7 speed oil change-20180511_112618-jpg
    Holding the funnel & hose up, slowly fill (gravity fill). It will spatter out occasionally as air passes through. Now remember 1.8 ltrs only!
    DSG 7 speed oil change-20180511_124906-jpg
    Allow oil to fully drain from hose. Remove hose & replace cap.
    Old & new oil. Do you believe your oil needs to be changed?
    DSG 7 speed oil change-20180511_130332-jpg
    Done.
    Dec 2008
    Sydney/Canberra
    To clarify, all you've changed is the diff oil.
    The Mechatronics oil, which is seperate, is not so easily changed.
    Also, there's an adaptor for the breather to push the PVC hose onto.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Aug 2017
    I would use vw oil only.
    Dec 2008
    Sydney/Canberra
    The diff just takes full-synthetic 75W90 gear oil. Nothing too special about it.
    '01 Beetle 2.0
    Jan 2015
    Melb
    I'd be happy using aftermarket oil in a diff. My falcon has done 275k miles on the original oil. I probably should change it soon.
    Albany, WA
    So this is not the DSG oil that u need to change every 60K>
    Dec 2008
    Sydney/Canberra
    Nope.
    These 7-speeds aren't considered serviceable as far as the DSG component of it goes. There's no service interval for the diff oil, but you can change it as often as you like, as per the above instructions.
    '01 Beetle 2.0
    Albany, WA
    Cheers thanks for that.
