Results 1 to 4 of 4
Thread: TPMS – How to Disable with ODBEleven
    May 2015
    I recently had a hairline crack repaired in my Omanyt 18 inch wheel on my R36. The repairer noted that my direct TPMS sensor was leaking and removed it from the wheel. Of course this has thrown a low tyre pressure light on the dashboard. (Not sure whether I will eventually replace this or not.)
    The question I have is how do I disable the TPMS using OBDEleven – there doesn’t seem to be much specific information on the net?
    Biscay Blue MY10.5 Passat R36 Wagon
    Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
    Atlantic Blue MY19.5 Golf GTI
    Options: Luxury Package and Sound & Style Package.
    Pacific Paradise QLD
    Cant you set the pressure reading in that wheel right down low and then save the settings so that it doesnt show up. Cant remember OBD having module to allow that
    Yes you can disable TPMS.
    In the B6 the TPMS controller (65) is part of the CCM (46).
    You can disable it in coding.
    May 2015
    Thanks kamold. I'm still a bit lost. I've sent you a PM.
