Results 1 to 10 of 10
Thread: Door Lock Actuator Latch
    Apr 2008
    Hi
    My three Door Lock Actuator Latch stop working from remote control (can not unlock 3 doors).
    I can unlock from inside the car by hand only and after that is working until I lock them again.
    Try to find it on E-bay, but there is a lot of different parts number:
    Front Right - 3C1 837 016 A (B) - 8J1 837 016 A - 3CD 837 016 - all is 7-pins
    Rear Left - 8KO 839 015 - 3C4 839 015 A (B-C-D) - 3CD 839 015 - all is 8-pins
    Rear right - 8KO 869 016 A (B-C-D-E-F) - 3C4 839 016 A (B-C-D) - 3CD 839 016 - all is 7-pins
    I am confusing about the first 3 letters and numbers and also about the following letter at the end (A,B,C...)
    Any help, please.
    Thanks
    My car is VW Passat wagon R36 2009
    R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
    Front
    3C2 837 015 A Door lock left - rhd
    3C2 837 016 A Door lock right - rhd
    Rear
    3C4 839 015 A Door lock left
    3C4 839 016 A Door lock right
    Apr 2008
    Thanks.
    Do you have any info on what is different between the first 3 letters/numbers - 3C2/3C1/3CD/8KO...
    It means its for a different car.
    3Cx is B6 Passat (x=variant)
    8Kx is Audi A4 B8 etc
    I can't comment on cross compatibility. If it's a different part number it generally means its a different part unless it's a supercession part. ETKA did not list any supercession part numbers for those listed above.
    Apr 2008
    Thank you so much Kamold.
    Dec 2012
    Just had the same issue..
    Can open the rear passenger door from inside then outside afterwards but once locked with the remote, I can't open the door from outside unless I do it by hand from inside first..
    I have a B7 Passat.
    Sent from my SM-N950F using Tapatalk
    MY11 B7 Passat 125TDi Highline
    Pearl Mocca Anthracite | Electric and Heated Leather | Folding Mirrors | Sunroof | Adaptive Lighting Package | Footwell Lighting | Park Assist 2 | Lane Assist | RNS510 | R36 Pedals | Scirocco MFSW | Front Lip | 20" Suzuka Wheels | H&R Springs | De-Badged | VCDS Mods | Alpine Mono and 8" Subwoofer
    Apr 2008
    I here door lock actuator is a common problem with all VW.
    Dec 2012
    Could you please let me know once you swap the actuator if it resolves the problem
    Apr 2008
    I will no problem. But first I will try to fix the rear left and right.
    Apr 2008
    Update:
    Rear left part no. 8KO 839 015 - 7 pins (E-bay $62.29) FIXED
    Rear right part no. 8KO 839 016 - 7 pins (E-bay $67.00) FIXED
    Front right part no. CZ 3C2 837 016A - 9 pins (Local wrecker $65.00) FIXED
    Once more THANKS to all members of the forum who helped me.
