Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Danger's OEM+ R36
  1. #21
    Jul 2013
    The tyres have now been replaced.
    Previous:
    225/35/19 - Goodyear Eagle F1 Asymmetric 3
    Now:
    235/35/19 - Michelin Pilot Sport 4 S
    During a 45 minute drive yesterday, there were a few instances of rubbing in the rear, so I'll look into camber adjustment.
  2. #22
    Nov 2014
    New Zealand
    Quote Originally Posted by danger17 View Post
    Previous:
    Now:
    Mine came with factory 19’s and I also run 235’s. In the four year’s I’ve had it I never noticed any rubbing until December last year when I was doing a long run with 4 people + luggage. And then only infrequently on undulations in the road and some corners taken at speed.
    2010 Passat R36 - Icelandic Grey / BT / MDI / Power Tailgate / RVC / Cargo Management System / 19" Lugano Wheels
    2005 35th Anniversary 350Z - Ultra Yellow / Stillen True Dual Exhaust / Motordyne MREV 2 and Plenum Spacer
  3. #23
    Jul 2013
    Hills District
    not the width of tyre, it’s the wheel offset, these wheels stick out 24mm with the same size tyres
    if your factory spec rubs it’s more likely the car was overloaded
    the rub area is the top outer edge of the wheel arch liner, adjust the rear camber can help but will reduce the life of those precious tyres
