Yes Ken, please keep us posted how it goes. Speaking from experience there's nothing worse than an intermittent fault that won't replicate when the car is at the dealer.
Question: In your initial post, you mentioned no lights/codes. Does that mean you have a scan tool so you can check for DTCs if the fault reappears?
Comment: my 2007 B6 Passat had an intermittent EPB switch that had to be replaced. I can't believe VW hadn't sorted out the reliability issues with these by the time they got to B7.
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
