Results 1 to 5 of 5
Thread: Mk4 gti- big turbo, big brakes, LSD etc
    Sep 2009
    brisbane
    I think it's time to part ways . Bought the car stock in 09 and its come a long way to end up like this.
    Details are
    My00 mk4 gti
    Odo: 180XXX kms
    Mod list
    Engine
    Custom Code stage 3 ECU
    Garrett GT2871R .64ar (56 trim)
    Bar-Tek T25 top mount cast exhaust manifold
    IE forged connecting rods
    Phenolic intake spacer
    ARP head studs
    ARP main studs
    ARP crank pulley bolt
    ARP cam pulley bolt
    Custom 3" TIP
    3" custom turbo back exhaust
    Siemens 630cc fuel injectors @ 3bar
    USRT billet injector cups
    Genesis high flow intank fuel pump
    044 Bosch fuel pump mounted in an 034 motorsports 1L surge tank
    USRT fuel pump wiring harness
    Enclosed k&n pod filter with stock positioned ICM
    CTS fmic
    Forge throttle body hose
    3" maf
    Forge 008 dv
    034 billet pcv valve
    Driveline
    Dieselgeek sigma 5 short shift kit
    ECS stage 1 clutch and 21lb SMF
    ECS Dogbone mount
    VF engineering motor and transmission mounts
    02J rebuilt and strengthened by Neat gearboxes
    Wavetrak TBD
    Raxles v2.1b axles
    Suspension-brakes-wheels
    KW V1 coilovers
    OEM R32 brake conversion. 334x32mm front. 256x19mm rear.
    Poly strut top mounts
    TT control arm bushes
    Whiteline 24mm adjustable rear sway bar
    Koya Drift teks 18x8.5 et30
    Pirelli P1s 225-40-18
    Exterior
    Blacked out badges
    Clear/smoked side indiators
    +25kw worth of stickers
    R32 replica front bumper
    R32 replica side skirts
    Seat Cupra R lip
    ECS stubby antenna
    Interior
    Dual column pod with NewSouth boost and oil pressure gauges
    Vent mounted Innovate wideband A/F guage
    Headliner DIY re-trim
    Rods, new piston rings and bearings were done at 151000km then again after my oil pump went at 155000kms. Engine has been rock solid since then. Oil changed every 5k using Penrite. Body is in great condition for its age. I've spent a lot on this car and I still love it so I'm not in any hurry to get rid of it but I kinda wouldn't mind a change.
    Asking $11000, a little negotiable but not really. I've dropped well over $30k into this car not including the purchase price so whoever buys it will be getting quite a bargain.
    Full build thread link in my signature
    Some more pics for clicks
    Sep 2009
    brisbane
    Took the car to A1 suspension and mechanical in tweed heads today to get the front end looked over. Passed with flying colours! Whoever buys this is getting a solid car. Bumpity bump bump.
    I'd like to add to Carlos comment's. I have had a fair bit of input in the car over the years.
    For all the fearsome rep of the big turbo. Off boost I'd be happy to let my daughter drive it as it is very docile. Quite a Jekyll and Hyde car.
    The suspension is pretty pleasant in the scenarios I have driven it, highway and suburbia. Much less aggressive than my polo. Yet still able to run quick on the track.
    I think you could also get a Pizza or two thrown in if you ask nicely.
    Sep 2009
    brisbane
    Haha, thanks mate. Yeah is very docile below 3.5k rpms and then the turbo wakes up definately can hook anybody who wants to have a look at it with a free pizza
    Munno Para West Adelaide
    Id just like free pizza! GLWS Carlos your cars been a big inspiration for my build! Who ever buys this will be getting a great car!
