EOI Car weigh in session
Hello,
I was wondering if anyone would be interested in getting their cars weighed using my Proform 5000lbs (2200Kg) vehicle scale.
Features of the scale are:
PROFORM's vehicle scale has been upgraded and now features Cross weight, Side/Side weight, and Front/Rear weight in addition to the standard weight and percentage for each wheel and total vehicle weight. The individual scale pads are 14 ½" x 9 ½" x 2 ½" with a 1,250 lb capacity per pad for a total scale capacity of 5,000 lbs. Scale is accurate to 1/10 of 1%.
If anyone was interested in corner weights and distribution this is a good opportunity to check.
Last time we held the gathering it was at a venue that was not low suspension friendly. So a venue will be required.
If there is sufficient interest the where and when can be the sorted.
Putting it out there.
Karl
- You may not post replies
- You may not edit your posts
Forum Rules
