It depends on the sump plug design. Some use a bolt with integrated washer which is designed to be thrown out and replaced each oil change. I think this is what your car will have. You can likely get away with reusing the bolt and washer once but they are designed to be thrown out and replaced each oil change.
Other engines use a sump plug which is reuseable and you just replace the crush washer, like my SQ5 uses.
2017 Ford Fiesta ST
