I have a 2010 CC. I have a warning on the dash about the rear left fog light not working.
I have checked the globe and it is not faulty. I have heard that there is a possible fault in the wiring harness in the boot lid.
Does anyone know where the cables run to from the light?
Passat CC 2.0 TDi and loving it.
Have u had someone check that the glove isn't actually working when u put it in reverse? It may be that the bulb is not the factory spec & throwing an error -but still fine.
I have fitted bright LED reverse lamps & get an error ALL the time. I have tried to eliminate the error using VCDS without success so I live with it.
