Dual Mass Flywheel
Well, 2009 Passat CC 2.0TDI with the 6-spd DSG - just noticed noise and a very slight vibration at idle. I understand the DMF is something that always fails around 150,000km.
This job is a little out of my league seeing you ideally need a lift for good access, and anyway, I'm too busy at the moment.
I'm waiting on a quote from an independent VW mechanic, but what's the likely cost range I should be looking at for this job - (labour and parts)?
Is it better to replace the DMF (they are quite pricey I believe) with a single-mass flywheel (cheaper I believe) in it's place; not sure why there is such a thing as a dual-mass flywheel?
Any guidance or advice would be greatly appreciated.
- You may not post replies
- You may not edit your posts
Forum Rules
