Results 1 to 10 of 10
Thread: ACC fault - electromagnetic interference
    Apr 2012
    Inner west, Sydney
    Hey guys,
    today the ACC in my VW CC stopped working.
    It gives ACC Error! on the dash, together with an exclamation mark.
    I checked with VCDS and it gives the following:
    Address 13: Auto Dist. Reg
    1 Fault Found:
    00272 - Function Disabled due to Electromagnetic Interference
    012 - Electrical Fault in Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101100
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 47
    Mileage: 88465 km
    Time Indication: 0
    Date: 2054.14.02
    Time: 18:20:26
    Freeze Frame:
    Count: 16
    Any idea what's going on?
    How do I fix it?
    Thanks.
    As a general rule, an isolated snippet of an autoscan is not very useful.
    Please post the full autoscan for context.
    Possibly something electrical such as low battery voltage or another consumer causing issues for the radar.
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|3D colour cluster|Quad LED tail rings|Climatronics upgrade|Dynaudio retrofit|B7 RLine Flat Steering Wheel|3AA CCM|TPMS Direct|B7 Adaptive Cruise with Front Assist|Discover Media retrofit|PLA 2.0|Lane Assist|BCM retrofit|High Beam Assist
    Apr 2012
    Inner west, Sydney
    My apologies. I only saved that bit. I will do a full scan this afternoon and post the result.
    The issue disappears after ignition restart and recurs after ~1-10km.
    Apr 2012
    Inner west, Sydney
    Code:
    Wednesday,27,May,2020,18:26:45:00007
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.9.0.2
    Data version: 20180927 DS296.0
    www.Ross-Tech.com
    VIN: License Plate:
    Mileage: 88720km-55128mi   Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 02 03 08 09 10 13 14 15 16 17 19 22 25 36 42 44 46 4F 52
              53 55 56 62 65 72
    VIN: Mileage: 88720km-55128miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Malfunction 0010
    14-Susp. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (BWS)       Labels: 03H-906-032-BLV.clb
       Part No SW: 03H 906 032 DQ    HW: 03H 906 032 AB
       Component: CC3.6-FSI-EU4   F   3490
       Revision: 5GH04---    Serial number: VWZCZ000000000
       Coding: 0000175
       Shop #: WSC 22690 959 89399
       VCID: 74E76AD117BB28EAC1-8020
    1 Fault Found:
    005717 - Please check DTC Memory of Auto. Distance Controller
                   P1655 - 004 -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 0
                        Fault Frequency: 6
                        Reset counter: 255
                        Mileage: 88465 km
                        Time Indication: 0
                        Date: 2014.10.17
                        Time: 18:20:26
                 Freeze Frame:
                        RPM: 1628 /min
                        Load: 32.1 %
                        Speed: 81.0 km/h
                        Temperature: 86.0C
                        Temperature: 17.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 13.843 V
    Readiness: 0000 0000
    Address 02: Auto Trans        Labels: 02E-927-770.clb
       Part No SW: 02E 300 012 F    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1906
       Revision: 04844002    Serial number: 00000810270086
       Coding: 0000020
       Shop #: WSC 05311 000 00000
       VCID: 1325094D32758FD278-8046
    No fault code found.
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 R    HW: 3C0 614 109 R
       Component: J104    C4 440 V3   0013
       Revision: --025---    Serial number: 00000786375621
       Coding: 0026015
       Shop #: WSC 22690 959 72028
       VCID: 2D51BFB5B41139224E-8078
    Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
       Part No SW: 5K0 907 044 AK    HW: 5K0 907 044 AK
       Component: Climatronic   130 0303
       Revision: 00002001
       Coding: 0000000000
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_Climatronic A01001
       ROD: EV_ClimaAutoBasis_VW46.rod
       VCID: 74E76AD1DFBB28EAC1-8020
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
       Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
       Component: Bordnetz-SG     H54 2602
       Revision: 00H54000    Serial number: 00000009102846
       Coding: E3E68F8B00041A0047978F0017000000000AFB47E4400165170000000000
       Shop #: WSC 05124 000 00000
       VCID: 3365A9CD52356FD218-8066
       Subsystem 1 - Part No: 3C8 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 151008 022  0602
       Coding: 00046997
       Shop #: WSC 05124
       Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
       Component: RLS     241108 054  0402
       Coding: 00209133
       Shop #: WSC 05124
    Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
       Part No SW: 1T0 919 475 L    HW: 1T0 919 475
       Component: PARKHILFE PLA H07 0021
       Revision: --------    Serial number: 06530828700746
       Coding: 101107
       VCID: 4487FA11C79BD86AB1-8010
    Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
       Part No SW: 3C0 907 567 J    HW: 3C0 907 567 J
       Component: AC201  RDW A    031 0232
       Revision: 00031000    Serial number: 00000000033432
       Coding: 0010000
       VCID: 326BACC9AD2F66DA13-8066
    1 Fault Found:
                012 - Electrical Fault in Circuit - Intermittent - MIL ON
                 Freeze Frame:
                        Fault Status: 10101100
                        Fault Priority: 7
                        Fault Frequency: 3
                        Reset counter: 88
                        Mileage: 88526 km
                        Time Indication: 0
                        Date: 2014.10.17
                        Time: 19:20:53
                 Freeze Frame:
                        Count: 16
    Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
       Part No SW: 3C0 907 376     HW: 3C0 907 376
       Component: DAEMPFUNGS-SG H07 0069
       Revision: 00000000    Serial number: 04110801910002
       Coding: 030180
       Shop #: WSC 05314 000 00000
       VCID: 66C300999167CA7A4F-8032
    1 Fault Found:
    01319 - Control Module for Distance Control (J428)
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 6
                        Fault Frequency: 6
                        Reset counter: 88
                        Mileage: 88465 km
                        Time Indication: 0
                        Date: 2014.10.17
                        Time: 18:20:26
                 Freeze Frame:
                        Bin. Bits: 00000000 00000001
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655     HW: 5N0 959 655
       Component: J234__31G VW10 HI   1815
       Revision: 19013000    Serial number: 0039BPPQ1MPI
       Coding: 0012615
       VCID: 7AFB44E935DF5E9A9B-802E
       Subsystem 1 - Serial number: 6333FTS614583018
       Subsystem 2 - Serial number: 6343FTS613293018
       Subsystem 3 - Serial number: 6353ETS6GFROVVNJ
       Subsystem 4 - Serial number: 6363ETS6PA1PVVNJ
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
    Apr 2012
    Inner west, Sydney
    Code:
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0030
       Revision: 00032000    Serial number: 3C5953507CR
       Coding: 0201821
       Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP   H4 0021
       Coding: 00000227
       Shop #: WSC 00000
    Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb-SRI1
       Part No SW: 3C8 920 870 B    HW: 3C8 920 870 B
       Component: KOMBI         H05 0107
       Coding: 140F00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
       VCID: 2A5BB4A94DFF2E1AAB-807E
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
       Part No SW: 3C0 907 530 J    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 2900R08A268263
       Coding: FDAFFF07000203009003
       VCID: 285F4EA19BF31C0ABD-807C
    Address 22: AWD        Labels: 0AY-907-554-V1.clb
       Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
       Component: Haldex 4Motion      4013
       Coding: 0000005
       VCID: 4487FA11079BD86AB1-8010
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3C0 959 433 AM    HW: 3C0 959 433 AM
       Component:    IMMO         052 0383
       Revision: 00052000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: 75E157D51CC131E2F6-8020
       Subsystem 1 - Part No: 3C0 905 861 G
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C8 959 760     HW: 3C8 959 760
       Component: J810                0801
       Revision: 00002000    Serial number: 00000000000000
       Coding: 0000001
       VCID: 72EB6CC96DAF26DAD3-8026
    Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
       Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1534
       Revision: 71009005    Serial number: 00000689288926
       Coding: 0005047
       VCID: 408FF6011383C44A95-8014
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 E
       Component: EPS_ZFLS Kl. 212    2501
       Revision: 00H15000
       Shop #: WSC 02069 000 90108
       VCID: 2C57B2B18F0B302A59-8078
    Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
       Component:    KSG PQ46 RDK 052 0412
       Coding: 00910A0001860E76360494157008DFCE105801
       Subsystem 1 - Component:   Sounder No Answer
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    1 Fault Found:
    01134 - Alarm Horn (H12)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 47
                        Mileage: 88477 km
                        Time Indication: 0
                        Date: 2014.10.17
                        Time: 18:30:34
    Address 4F: Centr. Electr. II (J533_)       Labels:. 1K0-907-532.clb
       Part No SW: 1K0 907 532     HW: 3C0 907 951
       Revision: --------    Serial number: 2900R08A268263
       Coding: 01010001
    1 Fault Found:
    01512 - Control Module for Sliding Roof
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 47
                        Mileage: 88458 km
                        Time Indication: 0
                        Date: 2014.10.17
                        Time: 18:13:15
    Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
       Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1534
       Revision: 71009005    Serial number: 00000512389004
       Coding: 0005046
       VCID: 4189F3051889CD429A-8014
    Address 53: Parking Brake        Labels: 5N0-907-801.clb
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   009       Serial number: 00000000201445
       Coding: 0000057
       Shop #: WSC 05311 000 08193
    Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
       Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
       Component: AFS-Steuergeraet    0136
       Revision: 00H04000    Serial number:
       Coding: 3526024
       VCID: 3467AAD1573B68EA01-8060
       Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0003
       Coding: 00000053
       Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul r    0003
       Coding: 00000053
    Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
       Part No SW: 6RF 035 187 E    HW: 6RD 035 187 B
       Component: Radio         565 Y510
       Revision: --------    Serial number: VWZZZ4J6204502
       Coding: 0E000400040010
       Shop #: WSC 00078 790 00101
       VCID: 4B95D12DEAC5171270-801E
    Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
       Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
       Component: J388   TUER-SG HL   0309
       Revision: 43004101    Serial number: 00000000705035
       Coding: 0000144
       VCID: 3169A3C5A8295DC26A-8064
    Address 65: Tire Pressure        Labels: 3C0-959-433-65.lbl
       Component:    RDK              0453
       Coding: 0161211
    Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
       Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
       Component: J388   TUER-SG HR   0309
       Revision: 43004101    Serial number: 00000000723869
       Coding: 0000144
    End-------------------------(Elapsed Time: 02:56)--------------------------
    Hmm voltage looks good.
    I'd probably start with just unplugging the radar and checking the pins and connector for any corrosion or damage.
    Clean with contact cleaner.
    If it persists would have to look at the relay and fuse for the radar.
    Sent from my SM-G960F using Tapatalk
    Apr 2012
    Inner west, Sydney
    I was going to give that a shot but it seems the front bumper has to come off to access the radar connector. Is that correct?
    You can just take the centre part of the grill out. No need to take the whole bumper off.
    In fact you can just undo the top screws and the ones at the front and then pull it out enough while leaving the bottom connected and get access to it
    Apr 2012
    Inner west, Sydney
    Thanks. I was planning on removing the grill tomorrow but I went on a long drive today (~200km) and the cruise control worked flawlessly.
    I remember now that the radar cruise stopped working the morning after a car wash. Maybe the car wash was too aggressive with the water jet and some water got into the connector, and it has now dried out?
    Quote Originally Posted by minorityracer View Post
    Sounds plausible.
    Would give it an inspection and clean regardless.
