Results 1 to 10 of 12
Thread: Driver's side mirror problem
    Aug 2013
    Question Driver's side mirror problem
    Hi guys,
    About a year ago, the driver's side mirror on my CC got stuck in and wouldn't fold out. I tapped on it with a bit of force and it started working again like it never happened.
    A couple of weeks ago I started having issues with the same mirror. The mirror would fold in slowly, but it wouldn't fold out. If I fold it out manually, it folds back in... I had to do that a couple of times until it stays out.
    I have also noticed the passenger's side mirror "waits" for the driver's side mirror for a couple of minutes, then it folds out.
    Any idea what's causing this to happen? Is there anything that I can do to sort this out?
    Many Thanks,
    Vexed
    Aug 2013
    I can hear some grinding noise now, I think there is something broken inside... Will try to open it later and see what I can find...
    Jun 2011
    Sydney NSW
    Sounds like something has gotten inside and is binding. This could then have damaged or broken something in the mechanism.
    Aug 2013
    Quote Originally Posted by wai View Post
    I hope not... If this is the case, do I need to replace the whole mirror? Or I can buy specific parts to fix it?
    Mar 2009
    U should be able to buy the mech to fix it
    Dec 2008
    Sydney/Canberra
    Look for a stip of felt tape, flapping about loosely, where the mirror housing pivots. If it's there, rip it out. It's what usally causes them to bind up.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Aug 2013
    Thanks guys, will let you know how I go later.
    Thanks...
    Aug 2013
    Hi guys, I removed everything from the mirror except for the frame that holds everything... How do you remove that to expose the motor?
    I couldn't find any mesh or anything in the way inside...
    By the way, I removed the bottom part of the mirror as well, but I forgot to take a pic...
    Thanks...
    Attached Thumbnails Attached Thumbnails Driver's side mirror problem-wp_20150820_20_25_40_pro-jpg
    Aug 2013
    I took the car over to the dealership to check the DSG, and I asked them to check the mirror as well. The mirror and motor need to be replaced, I was quoted $1050!!!
    I will try to find it somewhere else....
    Aug 2013
    Can someone please tell me what is the part number of the mirror? I understand each part in the mirror has a number, but I'm looking for the frame which holds everything and includes the motor. I have been searching around with no luck...
    Thanks...
