Originally Posted by
twin eng, twin turbs
I used 4mm wall thickness mild steel steam pipe bends for the runners for good reason. On my 1.8t audi a4 i made a similar manifold running a GT 25/40 turbo without any problem for years. Its so solid that it dosn't warp or crack. My mk2 has a similar set up with water cooling around the turbine flange which has kept the temps down preventing any cracks or gasket issues. After having made stainless manifolds in the past with thinner wall thickness (1.6mm) i have had issues with them cracking and flanges warping causing leaking gaskets. Thats why i make mine from mild steel with much thicker wall thickness.
Turbo is based on a GT35r with modified housings, ported and polished for improved flow etc
