Originally Posted by
h100vw
You should be talking to your GIAC supplier, I would expect them to datalog it.
It wouldn't be unusual to have a boost leak but logging is the quickest way to see.
A quick check of the PCV system involves, undoing the oil filler cap. If you can lift it off easily, the PCV is probably ok. If it is a bit harder to remove and runs badly with it off, the PCV system needs looking at.
Thats not how the PCV works on TFSI engines , its the other way around ..
Bug_racer supports the rebellion of the euro revolution
