Page 118 of 197 FirstFirst ... 1868108116117118119120128168 ... LastLast
Results 1,171 to 1,180 of 1970
  1. #1171
    Jul 2016
    Berry, NSW
    Quote Originally Posted by agentthumb View Post
    If you press and hold the button, I believe this activates Siri.
    Can anyone else with MIB2 confirm my potentially misguided assumptions?
    I have a 016 Golf with the discover media , that comes with CarPlay. When you press and hold the VC button on the steering wheel it activates SIRI. I didn't pay to have the VW Voice Control activated.
  2. #1172
    Apr 2012
    VCDS (VAG-COM) codes and programmable options for Golf Mk7
    Yeah this is what happens when you have CarPlay active. The VC button engages when pressed but still get the error message on speedo. It works which is great but I can easily just say "Het Siri". I'd prefer there to be a mute button.
    Fact of the matter is when an album has finished playing or even if I want to hit pause whilst GF is chatting to me, I could use this button and it would either jump to next album or would stop so my GF could continue chatting my ears off. Lol
    Gotta be a way to code it to function like one???
    I don't like to give up easy.
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  3. #1173
    Well I have completely figured how to make the infotainment colours customizable with multiple colours that are changeable through the infotainment system. With my Passat R it also changes the colours in the digital dash. So stoked to get this sorted again.
  4. #1174
    Mar 2015
    Warner, QLD
    Quote Originally Posted by recd View Post
    Thanks recd. I knew the Siri part works, I was wondering if you could confirm single press functions as a mute button or not in MIB2.
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
  5. #1175
    Apr 2012
    The past few post are about this. The MIB1 doesn't have CarPlay thus no VC function. The MIB1 I believe will perform as a mute button.
  6. #1176
    Mar 2015
    Warner, QLD
    Quote Originally Posted by Bassik View Post
    I think we are getting our wires crossed.
    MIB1: no Siri, but has dealer option to enable VC. If it's not active, then acts as mute button.
    MIB2: has Siri, also has dealer option to enable VW VC. (Short press activates VW VC, long press for Siri)
    What we are trying to work out with MIB2 is if VW VC is not activated, does a short press also work like a mute button like it did on MIB1. That's your original question right?
    We know your MIB2 doesn't work as a mute button, I was asking the previous poster to confirm his car behaves the same as yours to get a larger sample pool.
  7. #1177
    Apr 2012
    Fair call.
    For me a long press is no different to a short press. It will always activate Siri when CarPlay is activated. An error will display long or short press regardless if CarPlay is activated as well.
    No mute function at any point.
    I fear anyone with the MIB2 will no longer have this feature. Unless there is coding to disable the Siri VC.
    We need a coding guru
  8. #1178
    Mar 2015
    Warner, QLD
    Fair call.
    Ahh ok, I understand now.
    Just for your information, on my MIB1, I also get the stupid error message on the MFD, but it mutes my audio, so I don't mind.
    As a side note, have you tried holding the volume down switch? Not perfect but should achieve similar results?
  9. #1179
    Apr 2012
    Yeah I have tried that but it's annoying because for one you can't achieve the same volume once you bring it back up again. Holding down is easy coz it just turns off but holding it back up + means I have to time it so it doesn't start peaking loud music.
    Also I have a work phone that isn't Bluetoothed to my stereo and sometimes I might get a call. A quick mute unmute I can check if it's ringing or not.
  10. #1180
    Sep 2011
    Post
    To those who know about VCDS, can I please ask 2 questions?
    1. With having a JB1/JB4 on the car, if I do a VCDS scan, it is supposed to report no faults if it's all running well?
    2. I did a scan and it worked normally. Then I did it again and it produced lots of errors:
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Malfunction 0010
    14-Susp. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: Malfunction 0010
    2B-Steer. Col. Lock -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: Malfunction 0010
    5F-Information Electr. -- Status: Malfunction 0010
    A9-Struct. Borne Sound -- Status: OK 0000
    A lot of the erros said:
    8366 - Databus
    U1121 00 [009] - Missing Message
    What does this mean?
    Thanks!
