Rear Turn Signal lamps: Pace Car operation with Hazard warning lights (LED tails)
I recently received a communiqué from a forum colleague (thanks anonymous) enquiring about the instructions for the tweak above and including the video below:
https://www.youtube.com/watch?v=cc-NirmffCE
The video shows how the normal operation of the inner turn-signal lamps on the LED tails of a mk7 (which blink in unison with the outer turn-signal lamps) change to provide a "Pace-car" effect whenever the Hazard warning light switch is activated. Also shown on the video is the accompaniment of third brake light in Hazard warning-light dance.
Anonymous also provided a link to a German language webpage for the tweak - I acknowledge the work of the original author: "Golfi 30" on golf7freunde.de site. Anyway, after some thinking, translation and minor modifications, we finally developed a set of instructions that could be understood in our "Aussie" vernacular!!
I don't have LED tails on my car, but anonymous has implemented these instructions and he reports that the tweak works as shown in the video (thanks again Kim).
Rear Turn Signal lamps: Pace Car operation with Hazard warning lights (LED tails)- Instructions
- Select 09 - Central Electr control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 31347 and return to the "Open Controller" screen
- Select Adaptation - 10 from the "Open Controller" screen
- From the pull-down button check that the default settings for the adaptation channels shown in the table below are as indcated in the Existing Setting column
- Change the adaptation channels depicted in the table below to the values in the New Setting column (tip: use the "Search" box to locate the channels)
http://www.vwwatercooled.com.au/foru...OOthRpng-1.jpg
Notes:
- The table above provides a second option: Acknowledgement with Central Locking - change these settings if you want the "Pace-Car" effect with Lock/Unlock
- If the 3rd Brake light does not operate as per the video and you want this to happen, refer to my previous instructions HERE .
- Take care in the selection of channels and the settings (particularly when picking the correct "rechts/links" Leuchte commands) - please.............and double-check that the changes are correct before you press the Doit! tab
- If problems are encountered, remember the AdpLog.CSV file that resides in the Ross-Tech directory on the laptop that you used to make changes -this file will be your best friend if the tweak goes "pear shape"!!!
- I make no judgement, or statement regarding the compliance of this tweak with the Australian Design Rules. Those intending to implement these instructions should satisfy themselves in this regard - prior to proceeding.
OBDeleven Auto Rain Close
Hey folks, just wondering if anyone has done the auto close with rain with their OBDeleven? In the link below I can do srasge 2 and 3 but can't work out how to do stage 1. The option appears on the screen and the box is checked but no joy. I've also read that I might be one of the unlucky ones where it just don't work but as I say I can't work out how to do stasger 1 with the OBDeleven, or do I need VCDs?
http://www.vwwatercooled.com.au/foru...-84619-23.html
Sent from my Tab2A7-20F using Tapatalk
